Gas Cap and Button Issue
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by sejinro, Jun 2, 2020.
  1. sejinro
    sejinro Junior Member
    23
    Los Angeles
    2014 Prius Plug-in
    The fuel door button doesn't work anymore. When I push the button, nothing happens. Is there a fuse I can replace? Why would this happen? I've been using the manual release from the trunk.
    When I fuel the Prius, the gas pump stops every few seconds. This is really annoying. One time, it overflowed! How do I fix this issue?
    Love the car, but at 101K miles, looks like some issues are coming to surface.
    52,625
    are you getting the 'wait to refuel' message when you push the button?
  3. sejinro
    23
    Los Angeles
    2014 Prius Plug-in
    No message at all. It's as if there's no power to the button. i
  4. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    I think the overflowing and pump stopping are good clues. I recall something about the gas tank having an air tight design to keep fuel fresh, since it can be in there a long time. Perhaps that button also cooperates a pressure valve to allow a fill up.
  5. bisco
    52,625
    correct. check the manual, the system is malfunctioning, but i'm not sure if it's the lack of message, or an ecu problem not sending the signal to the button.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Check fuse #4 in the engine compartment.
    Yea Right and bisco like this.
  7. sejinro
    23
    Los Angeles
    2014 Prius Plug-in
    Checked it. Fuse looks good. I'll need to probably take it in.
  8. jerrymildred
    11,517
    14,164
    Tampa, FL
    Did you check the fuse with a meter? A blown fuse isn't always obvious to the eye.
    Still, even if the fuse is blown, whatever caused it to blow is likely to happen again.
  9. bisco
    52,625
    i can't wrap my head around the two issues. door won't open, and pump keeps stopping.
    somehow, i think they are related, because that is all part of the design.
  10. sejinro
    23
    Los Angeles
    2014 Prius Plug-in
    I didn't test it with a meter rather I replaced it with one of the spares.
    jerrymildred and bisco like this.
