Gas Cap replacement, Charcoal Canister location, P0446 CEL
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bklocke, Jul 16, 2018.
  1. bklocke
    bklocke Junior Member
    44
    Denver, Colorado
    I went to get my oil changed at Sun Toyota in Florida ($38.32 for Mobil 1, replaced filter and gasket - taxes included-Sunday special!) and the CEL came on on the way there. They were going to charge almost $90 to run a diagnostic, so I said no thanks and Auto Zone read (for free) a P0446 code which says:
    Definition: Evaporative emission control system vent control circuit faultOp, and Probable cause: 1. Open or short circuit condition, 2. Poor electrical connection, 3. Faulty CCV vent control solenoid.
    I have read in these forums that gas cap can be the easiest fix. However, I am not sure that is the issue, as it clicks tight and looks okay. Since the car has mostly lived in Vermont and has 212,000+ miles, there is a fair amount of underbody and rocker panel rust, and my muffler needs replacement.
    I would love your input on the following:
    1. Where is a good place to buy the cheapest new genuine Toyota gas cap for my 2006 Prius?
    2. Where is the charcoal canister located and how can I get a precursory look at it and the hoses connected to it to see if there is anything obviously damaged?
    3. Where should I look in response to #2 cause in the first paragraph, for a possible electrical short?
    4. If I replace the gas cap or do something else that solves the issue, how far or long would I need to drive the car to see the CEL go away?
    5. What other suggestions do you have for me.
    Thanks in advance for your wisdom - I love this forum - I don't use it often but it has always been helpful!
    49,708
    try camelback and olathe toyota. probably need to drive a few days for the light to go out.
    if it isn't the cap, you will need prius diagnostic software and a subscription to the service manual for troubleshooting at tech info.toyota.com
    all the best!(y)
  3. padroo
    padroo Senior Member
    2,763
    2,251
  4. jdenenberg
    jdenenberg EE Professor
    3,860
    1,859
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The way the charcoal canister gets damaged ( actually the activated charcoal gets used up ) is if you have a habit of overfilling the tank and raw gas overflows into the canister.
    JeffD
    ozzy1 and Raytheeagle like this.
