Gas Engine Shakes at Startup
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by 12VTAO, Oct 29, 2022.
  1. Elizabeth Grubbs
    Elizabeth Grubbs Junior Member
    Cincinnati
    My car does a similar rattle once every so often, it’s done it maybe 3x in the past 2 years…the research I’ve done this is what i believe is happening…an engine rattle when starting your Prius v, especially in wet or humid weather, is a very common issue across third-generation Priuses. It is typically caused by condensation pooling in the intake manifold overnight or an early-stage head gasket leak leaking liquid into the cylinders. I don’t think it’s an early stage head gasket and never had any engine issues other than the egr. In 8/24 at 175k I changed all the coolant in my radiator and inverter, and the cvt fluid. I change my oil every 5-6k miles using mobile1 synthetic extended performance which is 20k miles oil. Now 7/26 I’m at 211k and still no head gasket issues. My car doesn't use any coolant and only uses maybe 1/3qt oil when it’s dirty and due for a change. I honestly believe it’s from the condensation pooling like it says online and the times it has done it was after heavy rains and it sat 1-3 days without driving it.
  2. Brian1954
    Brian1954 Senior Member
    2,657
    1,059
    South Central PA, USA
    One small little detail that you did not list is that you replaced the engine at 165k miles. Why did you replace the engine?
    In a new thread you created today you wrote:
    Air_Boss, Mendel Leisk and Tim Jones like this.
