Gas engine turning on & off rapidly in rush hour traffic with hot weather and AC running
Discussion in 'Gen 2 Prius Main Forum' started by local_host, Apr 28, 2007.
  1. daveleeprius
    daveleeprius Heh heh heh you think so?
    429
    Seattle
    Sounds like a good reason to install the EV button mod.
    Dave
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Are you drifting along steadily at the average speed of traffic, or
    doing a bunch of go/stop and closing all the gaps too quickly? Try
    letting a nice long gap open in front of you while just letting the
    "creep" pull the car forward slowly, and wait till you get enough
    space for a "good burn" and actually use the engine for real. But
    just enough to start slowly closing the gap, not to close it quickly
    and then have to cram on the brakes behind the next car. The less
    you have to use the brakes the better, even in traffic like that,
    and if you think about the dynamics a little, and the average speed
    that everyone is making [regardless of individual behavior], you can
    map that into more efficient engine use. Yes, the SoC will float
    down around two or three bars under those conditions -- that's
    normal, and the side effect is that very light demand starts the
    ICE for propulsion.
    And if you're about to counterargue "...but everyone will jump into
    the gap if I leave one!", read this first.
    _H*
  3. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    <div class='quotetop'>QUOTE(Wetnabber @ Apr 28 2007, 02:33 PM) [snapback]431824[/snapback]</div>
    Now that's what I call South Texas! BTW, how did you get a package #9 on a 2006 Prius?
    Back on topic, where are you located? I was just driving in stop and go traffic yesterday from Culebra west of Loop 1604 all the way to 35 North of 1604 (long drive) and it was HEAVY traffic all the way. As luck has it, there was even an accident right in front of my neighborhood so I couldn't even get home. Anyway, I also experienced what you mention in my 2006 pkg #8. Culebra is a single lane road with a few traffic lights and you better believe that traffic was literally crawling. Surprisingly, I was able to go about 2 miles all the way to 1604 in traffic without the ICE starting at all. Of course I was being very conservative, I seem to remember the outside temp showing around 78* so I had the A/C off, vents off, radio off and I even turned the MFD screen off and rolled all 4 windows down to about eye level and I was actually quite comfortable with the slight breeze (fortunately it's not blazing hot yet her in S.A.). But once again, I did about 2 miles in traffic electric only and had no problems and the battery SOC was still reading just below 1/2 on the MFD (carefull technique of waiting a few seconds as the cars ahead of me pull forward then I gradually accelerate to stay in stealth mode and quickly let off to let it coast and charge until I reach the stopped car ahead of me again, you have to time it just right and predict the stop and go). The onramp to 1604 was empty so the ICE took me up the ramp but I had to merge with completely stopped traffic, this is where the similar condition began. As the charge slowly dropped while I was climbing a moderate hill I did start to notice the same pattern even as I came over the hill that it was extremely difficult to move at all without the ICE coming on, but like other said it's completely normal and I pretty much ignored it and let it happen. Like others also suggested, maybe placing the shifter in the "B" position to keep the ICE running would help in your situation, or perhaps the engine braking could be even more annoying than the stop/start. Anyway, eventually the traffic started moving around I-10 at moderate speeds which the ICE was required (and I was able to roll up the windows and turn on the A/C) and I still averaged over 52 MPG. You'll just have to try different techniques to see what works best for you, if you can't find a better solution then let me know when you're ready to sell the Prius (I might know some people who would like one). Oh, I've also had a Honda Insight, believe me, the Prius is way better than Honda's hybrids IMO but I do miss the 65 MPG I used to get sweltering in the Insight.
    edit: Perhaps the reason for the continuous stop/start cycling could be due to the battery pack temperatures from extensive use and Texas heat, it could be reaching high temps and every time you touch the accelerater with even the slightest demand it causes too much heat forcing the ICE to take over. Of course it's hard to be sure unless you have a can-view or something, but I suppose it may be possible.
  4. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(nark @ Apr 28 2007, 01:27 PM) [snapback]431800[/snapback]</div>
    DO NOT DO THIS!!!
    Frank Hudon showed us a burned-out Prius motor-generator (MG2) which he believes was caused by exactly this! Pressing on the accelerator tells the car to go, so it sends current to MG2. But holding the brake prevents the car from going. Since MG2 is connectred directly to the wheels via a reduction gear, it cannot turn with the car standing still. Thus you are sending current through MG2 but not allowing it to turn. Result: one burned-out motor!!!
    <div class='quotetop'>QUOTE(DaveLeePrius @ Apr 28 2007, 09:41 PM) [snapback]431986[/snapback]</div>
    The EV button would not help in this situation. With the SOC at 2 bars, the car would simply refuse to go into EV mode.
    To the original poster: I agree that it is annoying to have the engine turning on and off so much. However, think how much more annoying it would be to be sitting in traffic and have the engine running constantly and burning gas the whole time!
    My advice: Set the A/C temp where it is comfortable for you, and learn to live with the engine behavior, because it's the reason you are burning a tenth as much gas as every other (non-Prius) car on the freeway.
  5. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    Lol, how simple and how true!
  6. local_host
    local_host Junior Member
    75
    <div class='quotetop'>QUOTE(Bob64 @ Apr 28 2007, 05:05 PM) [snapback]431830[/snapback]</div>
    With the AC on and one or two bars remaining, ANY slight push of the accelerator causes the ICE to start up. In normal driving, the ICE stays off with light acceleration on a level surface, and speeds under 40/45/50 MPH .. despite the AC being on. I assume the stop & go driving doesn't allow the battery to recharge normally and when it gets down to a bar, it keeps wanting to recharge, however only a little bit at a time. It would be nice if there was a button which allowed us to keep the ICE on, and another button to stay in electric mode (I guess it's called the EV)
  7. local_host
    75
    <div class='quotetop'>QUOTE(efusco @ Apr 28 2007, 05:08 PM) [snapback]431832[/snapback]</div>
    Yes, that's because I can actually feel the ICE turning on and off. Even with the AC blasting and my MP3 player on "11". It's the sudden jerk/vibration of the car that I can feel. You can't exactly mask this. Maybe I'll get used to it and it will get smoother within time as someone else suggested. If by this time next year it's still an issue I might consider a trade. Who knows. I mean I do like the Prius, and I don't really want to get rid of it (not to mention deal with the hassles of getting another car) but I'd like to have a car I'm totally satisfied with, considering I'm not a millionaire and it takes alot of work for me to make the $450 per month payment (in addition to a mortgage and countless other bills).
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    It was alluded to but not explained above that if you're so annoyed by the ICE cycling off and on that you could put the car into "B" mode. As long as you're going 20+mph when you put it into B the ICE will continue to run even when you come to a stop.
    This will make you the same as every other car on the road in that you will be continuously idling and burning gas and creating pollution in traffic, but your sensetive bum won't have to feel the ICE start up and shut down.
  9. allargon
    allargon Member
    113
    Austin, TX
    The same thing happens to me in traffic. Hell, my ICE comes on in reverse.
    I keep my A/C at 76 in the spring. I will likely bump it up to 78/80 in the summer.
    Whoever said leave a long car length in rush hour traffic must live in an area with no road rage. Sorry, that's just not practical in metropolitan driving. I don't see motorists in LA or DC tolerating that sort of thing.
    Any Florida or South Louisiana people care to chime in? You guys don't get the higher temps like TX, AZ, NM, UT, MT, southeastern CA and NV do. However, you definitely get the humidity.
  10. richard schumacher
    7,664
    1,046
    United States
    <div class='quotetop'>QUOTE(local_host @ Apr 28 2007, 03:17 PM) [snapback]431797[/snapback]</div>
    Dude, get a grip. It's completely normal for the engine to do that under those conditions. I live in Dallas also, so I know whereof you speak and I sh!t thee not. Just set it and forget it. Think about all the gas you're *not* wasting.
    Us hot-climate dwellers most definitely want to leave the windows up and the A/C running as fast necessary, not only for our own comfort but also to keep the battery and its electronics happy. They are cooled by cabin air (that's the vent to the right of the rear seats), not outside air. Rolling down the windows on a hot day, moving or not, could actually reduce overall fuel economy because the battery system would eventually get too warm to run efficiently.
  11. bradysplace
    bradysplace Junior Member
    53
    front range
    <div class='quotetop'>QUOTE(local_host @ Apr 28 2007, 02:11 PM) [snapback]431768[/snapback]</div>
    Hi Local. Sorry your having such a time with the texas heat and the operation of your prius. Many thoughtful folks have offered some good advice here. You seem to revert right back to the awful heat issue. I live just north of Houston and for almost 30 years have dealt with the Texas change of seasons. I am also on my second prius (had an 06 and liked it so much I purchased a 07). Most prius drivers fall between those that practice no hypermile techniques (just drive it as a normal car) and those that are determined to get every efficiency out of the car. I think you will also find that most folks would agree that under certain conditions the starting and stopping of the ice is more noticeable. When taken in context of the overall positives surrounding the car - the occassional notice of starting and stopping of the ice is a small discomfort for most of us. In my two years of prius driving in Houston I have had to deal with the same heat and humidity that you are dealing with - its just not a problem for me or most of the thousands of other prius drivers in texas. The one thing most try to do on this forum is to remain polite. So politely I would like to ask you to lighten up just a bit on how bad you perceive texas temps to be. My job requires me to travel and I can say that my perception is that most places in the US have less than comfortable conditions at some time of the year - and the residents just adapt or move. Give all things a bit more time and if you just can't live with the car or the temps - you have options.
  12. Per
    Per New Member
    232
    San Antonio
    Seems like this is part of the "idiot-light" nature of the Prius. The car is so automatic it won't let you make any decisions. You should be able to let the ICE run so you could charge the batteries if that is what you want to do, just like you should be able to turn regenerative braking off. Hopefully, Toyota will make the next generation less microwaqve appliance-like, and let the driver make decisions.
    That is just plain mean!. If you really are an M.D., you should know different folks have different reactions to heat!
  13. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    In hot humid weather, there are six things which will help keep you cooler inside a car.
    1) Not sitting in direct sunlight:
    If the sun is hitting the driver, but not the passenger, the driver will feel hotter. Window film like the Huper Optik as noted above will help. It will also help lower the overall heat gain for the rest of the interior - but not sitting in direct sunlight is the more important factor.
    2) Lower the humidity:
    With lowered humidity, your perspiration has a better chance of evaporating and helping cool your skin. Put the A/C controls on recirculation. Every time warmer humid air passes the cooler air conditioner evaporator coil, humidity is removed from the air. With the system being on "recirc" rather than fresh air, the interior humidity levels will drop. (This helps #6 with its contribution.)
    3) Keep hydrated:
    Drink water. (This also will help #6.)
    4) Wear appropriate clothing:
    This is no time for a dark wool suit and tie. Shorts and a light colored cotton or cooling synthetic fabric shirt is what is called for. (Again, helps #6.)
    5) Cool air:
    During hot humid days, the only place you are going to get cool air is from the A/C compressor and evaporator. It must run . . . but you shouldn't need MAX COOL to stay cool.
    6) Airflow!!!!:
    Dry air blowing across your skin helps keep you cooler. Set the A/C to blow directly on you from the vents in the dash. The cooler the air is, the less air movement you need to stay compfortable . . . but that may not be the most efficient way of keeping you cool. More airflow, less cool also works!
    Doing 1 through 4 and 6 will lessen the amount of time the compressor needs to run in order to keep you cool . . . thereby saving gas and that annoying cycling of the gas engine.
    Adjust any or all of the above to your liking, but for better efficiency and less gas motor start stop cycles, set the temperature higher, but only to a point where you can still keep yourself cool with higher airflow.
    If you are going to run the A/C at MAX COLD anyway, don't complain about the Prius cycling the gas motor on and off. At least IT knows what it is doing for max fuel efficiency. ;)
  14. Tideland Prius
    16,555
    <div class='quotetop'>QUOTE(Per @ Apr 29 2007, 03:27 PM) [snapback]432210[/snapback]</div>
    yeah it's called shifting to neutral or brake harder. Both will bypass regen. Not a big deal if you want to waste your brake pads.
    and yeah you could idle the engine, you just have to know how ;)
  15. local_host
    75
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Apr 29 2007, 05:39 PM) [snapback]432212[/snapback]</div>
    Your post and others of similar ilk remind of the old joke:
    Patient says to the doctor- "hey doc when I move my arm like this, it hurts" -doc tells the patient- "then quit moving your arm like that".
    And by the way, thanks for the top 6 list (why not 10??) of how to keep yourself cool. But I think I do know how to keep myself cool, I'm a grown man for krissakes. Wait let me check, umm yeah ;-))
    I realize posting anything even the slightest bit negative in a Prius forum will let out the wolves of defense, so I can't say I'm all that surprised. My needs are very simple. I want a car that allows me to use the air conditioner the SAME way I've been using on ALL of my previous cars (if including rentals while traveling, that's like 100) without having the car jerk and vibrate as the engine perpetually turns off and on in certain adverse sitatuations, IE hot weather rush hour. I can now see that might be impossible with the Prius, since it's not a "normal" car. That's fine, I get it now. It's a real full-on hybrid and the technology is not something that I'm used to. Overall it's been fun to drive. It's just the other day when the engine started to cycle on and off every few seconds, it sort of freaked me out. Glad to know this is not a defect and that the engine won't BLOW UP or something due to the rapid on/off ;-))
    I guess it's my fault for not test driving the Prius in these conditions before I bought it. The only other hybrid I ever drove was the Civic, which apparently is not the same kind of hybrid and not a "real" hybrid? From what I can remember I think the ICE only shuts off at a STOP idle and not each time the accelerator is released (& no low speed electric-only cruising) .. Maybe I'm wrong..
    As I mentioned before I'll give it a year maybe a bit longer. If I can't get used to this, I'll trade and get an old school 100% ICE car again .. ... End of story \o/
  16. local_host
    75
    <div class='quotetop'>QUOTE(efusco @ Apr 29 2007, 09:00 AM) [snapback]432078[/snapback]</div>
    I'll try this, but traffic on this particular stretch is well under 20 MPH for much of it's duration. Sad but true.
  17. Per
    Per New Member
    232
    San Antonio
    In the Civic Hybrid, the motor and the ICE is bolted together, so they always runtogether. WHen you back off the throttle in the Civic, all the valves close, and fuel injection ceases, so you get close to a zero drag when the engine turns with the motor. The Civic is cheaper, but with a rear seat that does not fold, and a smaller truck than a regular Civic, it is much less flexible with what it can carry. The Prius will also outaccelerate the Civic hybrid, and should get better city mileage--highway mileage should be about the same. You also get several options on the Prius not available on the Civic. If you can get used to the quirks, you will probably be happy with the Prius--I just wish they would go further with the Prius setup, as I mentioned.
  18. local_host
    75
    <div class='quotetop'>QUOTE(Per @ Apr 29 2007, 05:27 PM) [snapback]432210[/snapback]</div>
    THANK YOU for understanding. You are right on. We should be able to have more control of how we want this car to operate. I also hope the next generation Prius addresses these issues...
  19. richard schumacher
    7,664
    1,046
    United States
    These are features, not bugs. On average the car does a better job managing itself than most people could or would. If Toyota allowed drivers to turn these features off most of them would start complaining about reduced fuel economy.
  20. Per
    Per New Member
    232
    San Antonio
    Why would turning off the regenerative braking hurt fuel economy? The whole idea with pulse and glide is to fool the car to turn off regenerative braking, which comes on automatically when you release the accelerator. Having a switch would make it so much easier. As far as having a say-so on when the engine runs, while it may reduce economy, it would eliminate an annoyance as stated by the original poster, and I get the impression he would sacrifice economy if he so chooses. The Prius would still get better mileage under those conditions than other cars!
