Gas filler door open message--ACT IMMEDIATELY
Discussion in 'Gen 4 Prius Main Forum' started by dslomer64, Jun 19, 2017.
  1. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Not sure if ever look for such a message. Maybe it's there, but remains unseen most times. (n):unsure:
    Prodigyplace likes this.
  2. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    It was unseen by me 100% of the time until yesterday, but I believe it was always showing. Go outside and pop the lid. There's the message. Shut the lid. Gone.
    But why/how would anybody look for that message when they're refueling? They're out of the car. Then they shut the lid. Message gone.
    Gen 2 (2006) and Gen 4 (2017)
    RCO and Prodigyplace like this.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    No mention of it in the UK user guide so I assume we don't have it.
    RCO likes this.
  4. Prodigyplace
    12,711
    11,848
    Central Virginia
    Ours has a warning sticker inside the fuel door.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Sticker on ours just says "Unleaded fuel only" and the word "Diesel" with a cross through it. I don't know why it says that as leaded fuel hasn't been available for over 20 years now and a Diesel nozzle won't fit in the filler tube.
  6. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    For anyone having a problem reading the text in the photo it says:
    NOTICE
    Complete refueling within 30 minutes
    of opening the fuel filler door.
    If refueling more than 30 minutes
    after opening the fuel filler door,
    push the fuel filler door opener
    switch again, or fuel may
    overflow during the refueling
    process.
    See Owner's Manual for details
  7. Prodigyplace
    12,711
    11,848
    Central Virginia
  8. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    In case anyone forgot, 30 minutes has NOTHING to do with anything. Page 264 and the sticker above apply to NOBODY.
    Bottom line: if you get "Fuel lid is open", either stop and shut it or BE SURE to PRESS OPENER SWITCH before attempting to refuel, because it will merely be an attempt: fuel won't go in.
    #28 dslomer64, Jun 23, 2017
  9. Since2002
    936
    1,098
    Duluth, GA
    The 30 minute message applies to anyone who opens the fuel lid door intending to refuel, but for whatever reason doesn't right away. Most people nowadays are refueling at convenience stores or in some cases travel plazas. So they might pull up to the pump, pop the fuel door, go inside to prepay, or even if using a credit card they go inside first to use the restroom, then wind up spending time looking at all the different snacks and drinks, maybe then sit at the bench and eat their hotdog, or make a phone call etc. and it could be 30 minutes before they get back to their car, or even 25 minutes, then the time spend going through the pump menu, which seems to take some people 2-3 minutes, and then time spent pumping, the clock could run out and fuel starts spraying out. Personally I think people shouldn't leave their car parked at the pump unless they are ready to pump, but I am just giving an example of what could sometimes happen to some people, especially at a travel plaza.
    I agree though that the sticker should maybe also mention that if you drive with the fuel door open the 30 minute limit does not apply and that you must press the fuel door open button again before refueling. Although finding some way to not make it sound like they are condoning driving with the fuel door open. One of those awkward, "You shouldn't, but if you do" messages.
  10. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Ah, gee. "Since2002" and several others who said 30 minutes is a correct, meaningful number, are correct.
    1) Power off and pop the lid.
    2) Message is "Refuel ready".
    3) Same message for 29 minutes
    4) At 30 min., msg is "Fuel lid is open".
    "Since2002" is also correct that mention of driving with fuel lid open should be made, but not just on the sticker--manual, too.
    But the typical driver is somewhat unlikely to see that message since he's unlikely to reenter the cabin. Even if he did see it and even if he did once read page 264, he still might just say, "Thanks for the info" and head toward the pump.
    Now his only hope is that he reads the sticker inside the lid and realizes that action inside the cabin is imperative. There is no guarantee that either will happen.
    Spill is imminent. But just this once. He'll remember after this.
    There's nothing foolproof about the situation except to say it's foolish to drive AT ALL with the fuel lid open or to take 30+ minutes to "complete refueling" (since opening the lid starts a hidden clock linked to a hidden valve/door).
    Perhaps an audible alarm in both situations would be foolproof. Or go back to Gen 2 fuel filling subsystem with no fuel lockout valve.
    I don't know about those ideas.
    So I suggest that Toyota describe the fueling process like so, notably replacing "Fuel lid is open", which sounds more informative than dire, with "Press fuel lid switch!", which will likely cue the driver to observe that the lid is indeed open, which is merely the symptom, not the problem. Pressing switch solves the problem.
    Refueling procedure
    1) Power off and press fuel lid opener switch.
    2) "Refuel ready" message will be displayed.
    (If not, see NOTEs below.)
    3) Begin refueling promptly.
    4) Do not top off.
    5) Close fuel lid.
    NOTE: If "Press fuel lid switch!" is displayed, an internal fuel valve has been closed because of improper fueling or driving. Attempts to fuel will likely result in spills. Pressing the fuel lid switch opens the valve.
    NOTE: "Press fuel lid switch!" will be displayed if:
    A) 30 minutes elapse between steps 2) and 3) above or
    B) the car is driven with the fuel lid open.
    The sticker should read something like so:
    If this lid was open while driving
    OR
    if 30 minutes have elapsed between opening this lid and beginning refueling,
    PRESS THE FUEL LID OPENER SWITCH.
    #30 dslomer64, Jun 23, 2017
    RCO likes this.
  11. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    You've previously indicated that you don't retain knowledge until you learn by doing in the school of hard knocks. So at this point, I'm not sure Toyota could have written anything in the manual or on a sticker to appease you, since you still wouldn't have "APPLIED" whatever they wrote.
    You hit an undocumented edge case. Thanks for letting the rest of us know about it. More complaining and sarcasm here isn't going to change anything.
    RCO likes this.
  12. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Not sure you're familiar with either concept. Mostly reporting "just the facts, ma'am", tidying up, making right, and sincerely trying to help, while possibly interstitially entertaining. But more than anything, most recently trying hard to bring an end to my thread, which I trust this does. If not, just avert you eyes. Peace out.
    jerrymildred, RCO and Since2002 like this.
  13. eric1234
    eric1234 Active Member
    392
    201
    Hamden, CT
    IMG_0125.JPG Note (as described more fully in my other post) - if your fuel filler has a black disc like the one in this photo, and that disc interferes with the latch, it may also close the fuel valve and cause fuel spills.
    dslomer64 likes this.
  14. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    My fuel door always opens, but barely, but well enough to cause no problem opening fully....
    Today, with "Refuel message" displaying, I pushed on the fuel door latch, but message didn't change. FWIW. Will try to remember to try again while refueling and report back.
    You know, the point of this thread has become (maybe always was) effective communication:
    The current "Fuel lid is open" message communicates information but not solution.
    The proposed replacement, "Press fuel door opener switch", communicates solution.
    RCO likes this.
  15. eric1234
    392
    201
    Hamden, CT
    If the message is that the door is open, isn't the solution to close it?
  16. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    I didn't. I immediately (after 1/2 mile drive) began refueling. And why not? Closing the door involves knowledge, reasoning, cause and effect, gravity of the situation, etc., and, in and of itself, did not tell me to close, then reopen, the door, which seems silly. If our front door is open and someone harmless-looking knocks, I doubt we'd close and open the door.
    Look. I KNOW WHAT TO DO. Others who have not yet spilled gas don't necessarily know. THIS THREAD IS FOR FUTURE owners.
    If I'm the only one who's ever done this, okay, I'm the dumbest owner there is. Don't change anything. But why two paragraphs about the consequences of the message in the manual, in which they don't even show the message. And why not mention gas-lid-open situation, which SURELY is more likely to occur than 30-minute lockout.
    I'm repeating myself. But I guess iii have to.
    RCO likes this.
  17. Prodigyplace
    12,711
    11,848
    Central Virginia
    Only because some people do not read the whole thread before posting. :(
    RCO and dslomer64 like this.
  18. eric1234
    392
    201
    Hamden, CT
    First and foremost, nobody is calling anybody dumb. The point of the forum is to share experiences and help each other out.
    The fact of the matter is that the GEN IV is a complicated vehicle. That's why there's two paragraphs about the message and the fuel filling process in the manual, as well as explanation of functional aspects that have I've never experienced: (i) Potential for a delay after requesting to open the fuel filler & a message showing when it's ready; and (ii) a 30 minute time out.
    I also discovered that if, while filling, one accidentally interferes with the door latch, it will cause the fuel to spill over - just like you discovered that when it gives the message "Fuel Door Open", pretty much the same thing will happen. We're both in the same boat in that regard, and are trying to help out our fellow GEN IV owners before they experience such messiness.
    My only point is that this is not a vehicle design issue. I disagree with the assertion that there is any deficiency of communication. When the car gives you the "Fuel Door Open" message - it is doing so as a warning. It is telling you that something is in an undesirable state. Just like when my colleague discretely tells me "Your fly is open". In both cases, most reasonable people would know what the appropriate next step is - without any need for explanation as to the cause or potential consequence.
    As an engineer, I'd disagree with the suggestion that this is a design defect. An engineer and designer can't possibly create an interface dialog for EVERY possible scenario. Usually, one opens their fuel door AT the pump, and then closes it after filling. I find the expectation that the designers to anticipate that someone would open the door, and then drive a mile to another gas station, and somehow create a message for that situation is a bit unreasonable. In the same way, I don't expect that there is a reminder message provided telling me not to interfere with the door latch while filling (although I'd certainly have appreciated one).
    In each of our cases, the true cause of the problem was a bit (of admittedly unexpected) operator error when using an acknowledged complicated fueling system. (An operator shouldn't open up the fuel filler door when 1 mile away from the gas station, as well as an operator shouldn't interfere with the door latch when filling).
    You didn't need to repeat yourself, I read your prior posts, and your repetition wasn't necessary. I was merely trying to suggest a more reasonable perspective than the immediate, reflexive "It is a design flaw" suggestion...
    RCO, wrprice and jerrymildred like this.
  19. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Whenever I screw up, it's a design flaw by definition. ;) ....... :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    So, is there anyone left who doesn't yet understand that the gas tank fill valve will close after having the fuel door open for 30 minutes or when you drive the car whether or not you've closed the fuel door?
    Any mistake we survive should be a learning experience. Thanks again, OP, for your transparency and vulnerability.
    RCO and kithmo like this.
  20. Prodigyplace
    12,711
    11,848
    Central Virginia
    It is a design issue in as much as they could have designed a larger door area to move the latch further away from the filler nozzle.
