Gas filling problem, rollover valve, gas tank replacement
Discussion in 'Gen 3 Prius Main Forum' started by John Schutt, Dec 28, 2016.
  1. John Schutt
    John Schutt Junior Member
    Fort Wayne
    Hello,
    I have a 2010 Prius and I can't put more than 0.2 gal into the tank at a time. I've taken it to the dealer and they've blown out the vent system. I took it to another mechanic and they tested out the vent system, charcoal canister, valves, etc. They say that the fuel tank has a bad rollover valve and needs to be replaced. They suggest a new tank (~$600 and labor ~$300.)
    1. Does my 2010 prius have a rollover valve?
    2. Is it part of the fuel tank?
    3. Does the entire tank need to be replaced?
    4. What about putting in a used one?
    5. Will this fix my problem?
    6. Any suggestions?
    Thanks,
    John
    52,819
    what did the dealer say after blowing out the vent? were there any trouble codes?
  3. John Schutt
    Fort Wayne
    He said that he didn't find any blockage and was wetting that my problem would be solved. If not, he'd put in a new charcoal filter. I went to get gas, and the filling problem was still there. So I bought a used evap system and put it in. I didn't want to go back to the dealer as I didn't trust them. The other place where I took it today said that one one of the canisters was bad and one of the valves was bad. He put the working ones in. The problem persisted when they took it to add some gas. That's when he said that it was a rollover valve that was stuck and that I needed a new fuel tank.
    52,819
    too much guessing. maybe have it evaluated at another dealer, or call toyota and tell them what you're going through.
  5. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Ask Mendel
  6. ChapmanF
    18,999
    I'm pretty sure if my car had that problem, I would definitely drop $15 on techinfo and review, first, the overview on how the evap system operates in the New Car Features Manual, and then any relevant Quick Technical Guides about it (under the QTG tab), and even the University of Toyota evap system course materials (under the Library tab) ... and then see if the Repair Manual had specific troubleshooting ideas for that particular problem.
    I would re-read that stuff even though I've read it before. I remember that it was fascinating and, yes, it really was that complicated. As I was reading for curiosity and didn't really have an evap problem to solve at the time, a lot of it didn't stick. The time stuff really sticks is when you've got a live problem you need to apply it to....
    -Chap
  7. Mendel Leisk
    42,316
    No clue. I searched my pdf of Repair Manual for:
    rollover
    roll over
    reliever (in desperation)
    No results.
    I'd echo @bisco 's question: any codes?
    Here's pdf of the applicable sections, maybe will help:
  8. bisco
    52,819
    could be mechanic speak. maybe ask him exactly what he's talking about, and how he knows that that is the problem.
  9. Mendel Leisk
    42,316
    I'm guessing it means so gasoline does start coming out in event of vehicle roll-over.
  10. Rebound
    3,996
    2,645
    Portland, OR
    In this thread, an owner with a 2006 had the exact same problem and reported that replacing the fuel tank filler assembly fixed the problem you're reporting.
    Robert Holt likes this.
  11. Prodigyplace
    12,711
    11,848
    Central Virginia
    The 2006 Gen 2 tank had a bladder in it. I thought the Gen 3 design did not have that.
    EDIT: Never mind. I see the issue was the filler assembly, not the tank :(
  12. Rebound
    3,996
    2,645
    Portland, OR
    Exactly. There are some pressure sensors inside the filler assembly which indicate to the pump that the tank is full.
    To be honest, it seems like any pro mechanic should know this because it's probably true of every car made.
  13. Prodigyplace
    12,711
    11,848
    Central Virginia
    It appears that the US Gen 4 has some sort of valve that opens when the fuel door switch is pressed to permit refueling. If refueling takes more than 30 minutes, you need to press the switch again or have fuel spill out.
  14. Rebound
    3,996
    2,645
    Portland, OR
    My Plug-in has something similar -- or maybe identical. I don't know what it does; I think it seals the tank to prevent any vapor evaporation/pollution.
  15. John Schutt
    Fort Wayne
    No codes.
    He said, "It's clear. I think that this will solve your problem."
  16. John Schutt
    Fort Wayne
    Thanks for all the great replies so far!
  17. ChapmanF
    18,999
    Well, kind of ... the issue is most likely in the ORVR behavior (onboard refueling vapor recovery), and the heap of sensors, valves, and tubes making all that work is maybe the most Rube Goldbergesque system in the whole car, not to mention Toyota seems to redesign it for every Prius generation if not more often, and other late model cars probably do all have ORVR systems too, and it's anybody's guess how similarly or differently those work.
    Upshot, there's probably not a pro mechanic around who knows the exact details from memory (unless your Toyota dealer is big enough to have one tech who never touches anything but your generation Prius). It's one of the few systems I know I wouldn't go near without reviewing it in the manual for the specific model year.
    -Chap
  18. John Schutt
    Fort Wayne
    Can you tell me what "techinfo and review" means? Is this a book? A part of this web site? ???
  19. John Schutt
    Fort Wayne
    What does this mean?
    Johnny Cakes likes this.
  20. Prodigyplace
    12,711
    11,848
    Central Virginia
    I believe they are referring to https://techinfo.toyota.com
