Gas Gauge was at 1/2 Full, Now showing Full, did not add fuel
Discussion in 'Gen 2 Prius Technical Discussion' started by txtabby, Oct 18, 2014.
  1. txtabby
    txtabby 2011 Prius 4
    134
    Austin, TX
    I left the house and parked on a hill parking lot, drivers side lower than the passenger. When I left, I was driving around and noticed the gas gauge, which had been at half full, was now showing full. I thought if I shut off the car, that might reset everything. It didn't. Anything I can do to fix this? Top the tank and see if that won't fix it? Or take it in? It sounds like a stuck sensor.
  2. Patrick Wong
    18,200
    6,493
    The fuel gauge should eventually reset on its own. You can expedite this by disconnecting the 12V negative cable for a few minutes.
    Or you can just fill up the fuel tank now, then the actual tank level will correspond with the current fuel gauge reading. Then reset the trip odometer on the MFD so that you have a convenient way to see how many miles have been driven since the fuel tank was filled.
    If the fuel gauge doesn't start to drop down after driving 150 miles, then start to be concerned.
  3. txtabby
    134
    Austin, TX
    Thanks for the fast reply. I'll try this tomorrow.
