Gas Guage not responding after fill up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by osiris12, Jan 19, 2012.
  1. osiris12
    osiris12 Owner of 3, yes three priuses
    119
    Upstate NY
    This happened a few times on my 2006 Prius but never for this long. I had a half tank of gas. Filled it up (maybe a little too much). Now the gauge is stuck on a half tank even thought it is actually filled.
    I drove 55 miles and it still reads a half tank. Is this indicative of a systemic problem or normal operations? It is cold here in the North East US. So I'm sure that has something to do with the gauge not resetting?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
  3. osiris12
    119
    Upstate NY
    Excellent! Thanks firepa63. I'll perform those steps after work tonight and let you know what happened.
  4. Patrick Wong
    18,210
    6,516
    Re: Gas Gauge not responding after fill up
    How much fuel did you purchase? If 3 gallons or less then the fuel gauge probably won't register the change.
    You could disconnect the 12V battery negative terminal cable where it connects to the body, for a few minutes. When the 12V power is restored and you first turn on the Prius, the fuel gauge will blink one bar and eventually show the correct amount.
    Otherwise, you'll need to drive a sufficient distance so that the tank is at least half-empty, before the fuel gauge will start to register further decreases.
  5. osiris12
    119
    Upstate NY
    Hi Patrick,
    I believe it was 3.8 gallons or so (1 bar before half). I'd rather drive it than disconnect the 12v battery. I'll lose my radio stations and whatnot with that process... I've done that before when I needed a new ICE battery.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    That might not have been enough to trigger a recalculation of gas volume. It should be close, but not a sure thing. I'd wait until you can add five gallons or more and try it again.
    Tom
  7. Photo Ninja
    Photo Ninja New Member
    Pittsburgh, PA
    This happened to my '05 in the summer. It wasn't more than 4 gallons put in at the time.
    It ended up eventually dropping below the half way mark after a bit of driving on it's own and not sticking again when I filled up afterwards. At the time, I had reset the miles since it didn't do it automatically to track how much I had on the tank... just in case... so I could judge how many gallons were used based on the average mpgs. I've only had it happen maybe twice though...
  8. jebko
    jebko New Member
    This was an easy fix on my 06. In 2010 my dealer charger me 106$ even tho
    I have the 100,000 mile extended warranty. That wont be my next dealer.
  9. richard schumacher
    7,682
    1,064
    United States
    Don't blame the dealer: resetting the fuel gauge is not covered by the extended warranty. Read the fine print about exclusions.
  10. Moadeeb
    Moadeeb Junior Member
    Clarification Please.
    When ODO/Trip button is pressed 3 times, does the dash indicator show a change to "Trip B" then "ODO"?
    My 2008 is not responding as written.
