Gas mileage and cold weather
Discussion in 'Prime Main Forum (2017-2022)' started by JMalmsteen, Jan 6, 2018.
  1. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    For those of you experiencing the cold weather, have you noticed a major decrease in gas milage? I was getting close to 70 mpg on my commute home, with no charge, and have now been getting under 50 mpg. Temperatures have been around 10-15 degrees F.
    HPrimeAdvanced likes this.
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Normal with any vehicle
  3. JMalmsteen
    287
    266
    My WRX is getting decent gas mileage, not much of a drop off. I drove it from NY to PA yesterday and there wasn't a huge difference in the mpg. The Prius is showing a larger decline, so I was wondering if this was particular to the Prius.
  4. mdhare
    mdhare Member
    59
    33
    Madison, WI
    In these parts it has been 15f or colder since Dec 25. My last tank was significantly less efficient, 70mi runs down from 65 or so to 45 mpg with heat at 66f. Biggest impact as expected has been lack of EV ability for short city trips. Car spends its at home time in a garage kept no colder than 32f.
    JMalmsteen and HPrimeAdvanced like this.
  5. Salamander_King
    Salamander_King Senior Member
    11,026
    8,987
    New England
    I think hybrid car in general lose more efficiency in cold. Our Civic hybrid and Gen 3 lose ~20% efficiency in winter. My Prime is now getting about 58 mpg on GAS only compared to 70+ mpg in summer. But that's all relative. From 70 mpg to 50 mpg is a big drop by number, but I bet you still can't find any conventional engine car that get better mileage than your Prius. ;)
    #5 Salamander_King, Jan 6, 2018
  6. bisco
    52,927
    the reason there is a bigger difference between a hybrid and a gasser is the very reason a hybrid is more efficient.
    a gasser runs the engine all the time, so in colder weather it's just the efficiency reduction from friction etc.
    a hybrid has to run the engine more to maintain minimum operating temperature and provide heat when requested.
  7. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    I've driven 45 miles since 12/31 in single- temps mostly. Right now it's 3. Mpg under 30, partly because of almost all short trips and turning temp to ECO temp off. This tank: 275.5 miles, 49 (so really 45) mpg. Gonna be hard to bring it back up to overall real 60. Whatever, it's still more than they said I'd get.
    JMalmsteen likes this.
  8. JMalmsteen
    287
    266
    I drive in the winter with a blanket around me. I leave it on the seat and wrap it around my legs, which makes it much more comfortable. The only place I notice an issue is near the floor. There seems to be air coming in or a lack of heat. I usually wear stockings and a skirt to work, so I'm considering getting leg warmers to wear in the Prius (if they still make those!)
  9. El Dobro
    El Dobro A Member
    7,106
    3,282
    Come the warm weather, everything will be back to normal+.
  10. mercat68
    mercat68 Active Member
    311
    216
    Mount Airy, MD
    My fully charged estimated range dropped from a high at one point of 36 miles this past summer to 27 miles this week. I’m not surprised (and grateful I’m still getting 27 miles) - brutal cold is hard on batteries and it’s been brutally cold in the D.C. region lately.
  11. huskers
    huskers Senior Member
    2,551
    2,490
    Nebraska
    Turn the heater on. You only live once.
  12. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    My guess is the loss in fuel economy viewed as a percentage of the regular fuel economy is probably pretty similar for both cars. If I own a Land Barge that gets 12MPG, and it loses 10% of it's fuel economy, that's 1.2MPG. If I have a Prime that's getting 70MPG, a 10% loss here would be 7MPG.
    Sidebar: read yesterday on ChargePoint info., the average electricity powered car is rated at 3 miles/kWh; my Prime has several times displayed over 6 miles/kWh!
    I love my Prime!
    Liz Waters and JMalmsteen like this.
  13. bwilson4web
    16,554
    Hi Jen,
    There are several Prius and Prime specific tricks we use to improve cold weather performance. But it helps to document what is going on.
    Do you have a way to video record the instrument panel showing the problem? This will help us understand your specific conditions.
    Could you give us two addresses, one near your home and the other near work so we can look at your typical commuting route? We don't need your home or work address but ones within a block or so that Google Map traces your commuting route to get an idea.
    Do you air your own tires? Cold weather reduces the tire pressure and increases the rolling drag. So it is important to top them off after the cold weather arrives.
    Thanks,
    HPrimeAdvanced and JMalmsteen like this.
  14. JMalmsteen
    287
    266
    I do it because the seat is cold and I'm always cold, so a blanket makes the first few minutes more enjoyable. I don't have the heat blowing in any car, just personal preference, not to save gas. If it's on low I don't mind it.
  15. JMalmsteen
    287
    266
    I have gotten almost 40 mpg doing the same drive in the WRX. I got around 34 mpg. So, 6/40*100= a 15% difference. For the Prius, 70 mpg vs 45 mpg, 25/70*100= a 35.7% difference.
  16. JMalmsteen
    287
    266
    My commute is from West Hills, NY to Chappaqua, NY. This is around 56 miles. It takes 2.5 hours to get home because of traffic, that's why my gas mileage was 70 mpg!
    I also recently changed the wheels. I kept the same size wheels and tires, but I'm wondering if that could be impacting the mpg, but it shouldn't be that bad. The wheels are 20 lbs vs 15 lbs for the stock ones. I replaced the wheels since one was supposedly bad, Toyota wouldn't replace it under warranty, the original rim was around $350, the replacements were $94 each. I originally bought one to have a spare so I bought three more.
  17. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    OUCH!! One factor with the WRX, it is turbocharged, so that might have a lot to do with it. Also, my son had an Evo & his friend had a WRX; neither of them got higher than 25MPG in Socal; a testament to your "kinder" driving style! They were both major Hot Dogs! My son now drives a 2015 Prius! Like father like son! (I had an Acura Type R, much coveted by this son, until I bought a new 2012 PIP!) This son will probably be a Prime candidate soon!
  18. JMalmsteen
    287
    266
    40 mpg is cruising in 6th gear trying to get good gas mileage. Normally, I don't get anything near that. When I test drove an Evo, I got 11 mpg and I wasn't driving crazy.
    The mpg on the odometer is 30.6 mpg, so not bad!
    If you think 40 is good, on a trip from PA to TN, I got 50 mpg in my '16 vette in 7th gear and eco mode using cruise control. That was truly ridiculous :)
    We got tailgated and passed by a Prius that day!
  19. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    My Type R averaged 21-23 MPG, and had to run on Premium!! A real Gas Hog! But that little 8800 rpm 4-banger ate V-8s for breakfast!! That car saw 100+ mph almost every single day I owned it. Problem is, they tried to steal it at least 5 times (I only had a carport). This car and the Honda Civic (I owned both at the time!) were the most stolen cars in our area. Finally ended up selling the Type R to a cop (the car had just over 100,000 miles and ran/looked perfect!). 2500 lb rocket! I want that in a Prime coupe!!
  20. bill@bfv.com
    [email protected] Junior Member
    massachusetts
    We've noticed two things over the past month when we've had winter temperatures here in Massachusetts. First, the big battery doesn't charge more than 19 miles worth ... in the summer we were getting as much as 35 miles from an overnite charge.
    Second, instead of averaging 200 mpg when we were taking short trips, where we were almost exclusively driving on battery power ... now we're averaging low to mid 60s for mileage. It's still great ... but our first 5000 miles on the car averaged about 185 mpg ... and we drove about 3000 of those miles at 200 mpg.
    Now in the cold weather, the gas engine is on most of the time -- probably because we're using the heat, defrosters and electric seats. We do like those heated seats -- so it's worth the trade-off in mileage. But I do wish we could get more out of the overnight battery charge.
    And as others have commented, the heating system is "OK" but the interior doesn't really warm up until you drive the car for 20 minutes or more. It obviously depends on the outside temperature. But our other Priuses have all had great winter heat.
    mercat68 and JMalmsteen like this.
