Gas mileage at specific speeds
Discussion in 'Gen 3 Prius Fuel Economy' started by Dead12VBattery, Aug 5, 2018.
  1. Dead12VBattery
    Dead12VBattery Junior Member
    Amsterdam
    I've been trying to measure gas mileage at specific speeds to get some idea of what the relationship between the two looks like (more or less quadratic I suppose, but the parameters would be interesting). However, it's hard for me to measure accurately due to wind and traffic conditions.
    My estimate so far is based on the following conditions:
    • Temperature around 20 C (68 F)
    • Averaged between headwind and tailwind
    • No AC
    • Hybrid battery fully charged
    • Cruise control at the indicated speed on the speedometer
    • Actual speed measured using the trip meter (which is lower than the speedometer, and consistent with GPS speed measurements)
    • Fuel consumption measured using the trip meter
    • Measured over at least 2.0 km (1.2 mi) with almost no net height difference
    My own results (again, probably inaccurate):
    • 90 km/h (56 mph); real speed: 84 km/h (53 mph); consumption: 3.5 l/100km (68 mpg)
    • 110 km/h (69 mph); real speed: 103 km/h (64 mph); consumption: 4.0 l/100km (59 mpg)
    • 120 km/h (75 mph); real speed: 113 km/h (71 mph); consumption: 4.5 l/100km (53 mpg)
    • 140 km/h (88 mph); real speed: 132 km/h (83 mph); consumption: 5.7 l/100km (42 mpg)
    Has anyone else done this? If so, what are your results?
  2. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I am wondering what tire size and tire pressure your Prius is running? It looks like your displayed speed vs real speed is more out of line than most of the American spec of 1.5 to 2 miles per hour different. Maybe it's EU regulations to display an even faster speed than American cars so drivers can slow down more?:eek: I think there were topics about this but I am at work so not the right time to do a search.:whistle:
    Grit likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Those results are similar to mine with 15" tires 44psi on all 4s. If you drive at that temp on a regular basis, might as well grill block.
    When I set cruise control on 55mph, and reset trip A, cons. speed is always 53mph. Techstream says 53mph also when cruise control is 55mph.
  4. Dead12VBattery
    Amsterdam
    Yes, it's pretty normal here for the deviation the be about 7%, though supposedly it's getting smaller in newer cars. From what I've read, the manufacturer must guarantee that the displayed speed is never below the actual speed, regardless of conditions, so they add a large margin.
    Note that the fact that the trip meter is accurate shows that the car does actually know how fast it's going.
    RMB likes this.
  5. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    RMB and Dead12VBattery like this.
  6. Dead12VBattery
    Amsterdam
    Thanks Kevin_Denver! Exactly what I was looking for. Seems pretty consistent with my own measurements too.
    Amazing fuel efficiency at low speeds BTW, I guess the serial hybrid design really pays off.
    RMB likes this.
