Gas Mileage Went Down 11 MPG
Discussion in 'Gen 4 Prius Fuel Economy' started by Coast Cruiser, Dec 2, 2016.
  1. gilbertarguelles
    gilbertarguelles New Member
    US
    2013 Prius Plug-in
    My milage and how much charge i get always drop when it turns cooler in central California on my 2013 prius plug-in. Cooler here as not very cold. Same for this year. Most my trips are about 5 miles out and i plug-in most of the time. I went 2000 miles at 255 mpg in oct./nov. But dropped to 750 miles on the next 2 fill ups. My long trip not plugging in winter mpg is 47-51 and summer 51-56 with the best late spring and late summer with no a/c or heater needed . Temperature will drop my charge range from summer of 11.1-12 miles and winter as low as 9.1 miles. I wonder what really cold does to the charge range.
    bisco and Coast Cruiser like this.
  2. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    Made the run from Phoenix to LA yesterday afternoon. Strong (40 to 50 mph) headwinds and blowing sands. Overall mileage on full tank 37 mpg. A few weeks ago I made the reverse trip LA to Quartzite with a similar tail wind. 68 mpg @ 77 mph (right on the cali legal limit :))
    RCO and Coast Cruiser like this.
  3. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I find it kind of strange, that wind and colder temperatures affect the Prius gas mileage so much. Is the battery that sensitive?
  4. Prodigyplace
    12,712
    11,848
    Central Virginia
    You really think it strange that winds affect a vehicle that gets a lot of its efficiency from its aerodynamics?
    first_superior_prius likes this.
  5. Coast Cruiser
    2,267
    2,571
    I ain't got no stinkin wind where I live. :ROFLMAO: :LOL: :confused: Just kidding. Only a little bit of wind occasionally. I do think it's weird that temperatures affects the battery. Shouldn't Toyota advise us of that fact? When they test these cars, they should also list the "winter" gas mileage.
    And all those guys on YouTube that test drive the Prius, they need to drive around in the winter and snow, and tell us what kind of gas mileage they're getting. That would be very good information for people who live in the cold weather states, don't you think?
    But I'm perfectly fine with 51 MPG. Where else are you going to get that??? :LOL: I'd be happy with only 40!
  6. Mendel Leisk
    42,331
    Temperatures don't just directly affect the battery, or hybrid system, or engine. The car has an ambient temperature sensor, and as temperatures drop it intentionally changes engine and hybrid system behaviours. Delaying/reducing engine shut-off, for example. It's sort of an edict from on high.
    You can reduce the effects, by for example: lowering cabin temperature setting. Setting the vent system to Auto and then lowering cabin temp setting is a one-two punch I find will push the car to cross the engine shut-down threshold, especially when halfway through warm-up.
    And on top of that is the direct effects: greater heater demands, coolant taking longer to warm.
    RCO and Prodigyplace like this.
  7. Coast Cruiser
    2,267
    2,571
    COMPLICATED! :ROFLMAO:
    I keep saying it, and I'll repeat it again... this is the most complicated and confusing vehicle I have ever owned. I realize it's a "hybrid" at all, but can't they still make it simple? I'm glad we only have ONE season out here. (OK, maybe one and a half. We get a slight "winter.") So I will know what to expect as far as gas mileage goes. Between 51 and 64. LOL!
    Those people that drive in extreme cold and snowy conditions, their mileage may vary from 18 mpg to 35 mpg? Or whatever. If I lived in those conditions, I would top off my gas tank at least once a week.
  8. Prodigyplace
    12,712
    11,848
    Central Virginia
    All cars get worse gas mileage in the winter, except plugins - They tend to get less range which amounts to the same thing.
    You can't have the magic without a complicated system powering it
  9. Coast Cruiser
    2,267
    2,571
    Keep in touch, prodigy. Let us know what kind of gas mileage you get in the snows of Virginia. (Beautiful state, by the way.) Now that I am older, retired, etc., I usually refuel my car when it reaches 1/2 tank left. Or 1/4. I don't need to hyper-mile, I know the car gets good gas mileage. I don't need to play with it. So I just use caution, and make sure I always have enough gas. (And buy a hot dog while refueling. ;))
  10. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    I have a new theory on poor winter mileage. I have noticed with the scangauge that ICE coolant temp will drop very fast when the engine turns off, especially if I'm venting the heat into the cabin with the heater. I have a lot of stop lights and stuff where I will lose temp and it spends a lot of the drive at around 160F instead of 195. I figure it's probably not as efficient at that temperature. And the battery can be 20-30 degrees cooler as well on some trips - I would imagine the same is true of it.
    It's probably more pronounced on a hybrid because the engine being off causes the coolant temperature to drop in ways a regular car wouldn't experience.
  11. Prodigyplace
    12,712
    11,848
    Central Virginia
    I know the Gen 2 Prius actually had a thermos bottle to keep the coolant warm. I have not noticed that on my Gen 4, though.
  12. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    It is simple, buddy. All you have to do is select climate automatic and leave it there. Then all you ever need is to alter the temperature to suit and turn it off/on as required, just like your old car. ;)
  13. bisco
    52,831
    wah-wah. i go from about 16 in summer to 12 in winter. that's all back roads 30-40 mph.:(
    RCO likes this.
  14. Coast Cruiser
    2,267
    2,571
    I'll try it again on Auto. But every time I adjust the temp, or fan speed, the Auto turns off.
  15. Mendel Leisk
    42,331
    I don't understand. Well at least the temp setting: that's always your prerogative; you pick a temperature. Or am I misunderstanding?
    Fan speed: yeah once you set a speed it's locked. To unlock just hit auto again.
  16. Coast Cruiser
    2,267
    2,571
    I don't know Mendel, I just do it the simple old-fashioned way. I really don't need all this "auto" stuff.
    If everything gets too convenient, I might doze off while driving! Too many hamburgers makes me sleepy.
    RCO and Mendel Leisk like this.
  17. Prodigyplace
    12,712
    11,848
    Central Virginia
    Auto Eco for climate control will help you get your good mileage even in PWR mode. It sets fan speed, which vents, and recirculated or fresh air to meet the temperature setting. Front defrost also turns off Auto.
    Set your temperature to 32 as the "keep awake" temperature:LOL:
    RCO likes this.
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    My mistake, set the temperature as required, Then press Auto!
    If you try to change the fan speed in auto you will take it out of auto, but shouldn't if you alter the set temperature while on auto to the best of my knowledge.
    Prodigyplace likes this.
  19. Mendel Leisk
    42,331
    I think, if you set the fan speed while in Auto, it's takes the fan speed off Auto, ie: the fan speed is locked, at whatever you set. But mode will continue to be automatically chosen, say vent, vs high/low, vs heat, vs heat/defog. If you set a mode, then that too is locked, at whatever you set. And that's more-or-less all Auto does, if I'm not mistaken.
    Kramah313 likes this.
  20. Prodigyplace
    12,712
    11,848
    Central Virginia
    I think Coast needs to RTFM Page 515.
    krmcg and RCO like this.
