Gas mileage went way down ??
Discussion in 'Gen 3 Prius Fuel Economy' started by cindyh1, May 5, 2012.
  1. cindyh1
    cindyh1 New Member
    59
    MISSOURI
    I knew when I bought my car it wouldn't get optimum mpg as no car would with the many short trips I have to make every day but I have 5000 miles on it already and have averaged approx 46 with all the city and highway combined.
    I took it into Toyota last week for the tire rotation and ever since it has been horrible. There were 120 miles on the tank and I refilled because I couldn't stand to see it staying around 39 on the computer. I have never seen that before. I checked the tired and they had brought them down to 32psi so I put then back to 40/38 and refilled. Not noticing much of an improvement, sadly. Hovering at 40 mpg still. Weather has changed a lot. Temps much higher daily mid 80s to low 90s.
    Any ideas on what it can be. This is my first summer with the car and yea the ac has been on nonstop with the higher temps.
  2. 6lark5
    6lark5 Junior Member
    33
    Elk Grove, CA
    2012 Prius Alpha
    What temp do you have the a/c on?
    I run it on high for a minute and then set it to 75-76.
    What brand/model/size tires? What is the max PSI on the sidewall of the tire?
    There is a sticky somewhere titled "why is my mileage low" or something to that affect. Read it.
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I hope you're not running the AC hard. Short trips and heavy AC use will drop mpg drastically.
    Tire rotation can drop mpg slightly if the tires are worn according to specific alignment but that wouldn't cause a large drop and it would be very temporary.
  4. cindyh1
    cindyh1 New Member
    59
    MISSOURI
    Still running the factory 15" tires max pressure is 44. I keep the ac on high then when it cools off just turn the fan down. I will increase the temp instead and look for the thread. Thanks. I love my car, I will never own anything else.
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
  6. almypal26
    almypal26 Member
    101
    So Cal
  7. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I requested the tire tech. at Costco to
    fill all four tires with 44 PSI which is max
    sidewall pressure and they did.
    They also fill with 44 psi when I have
    the tires rotated. With 44 PSI in
    each tire afte 61,000 miles they are
    wearing evenly, and will obtain
    maximum treadlife.
  8. JeffHastings
    JeffHastings Member
    223
    79
    Whippany, NJ
    Tire pressure makes a big difference. I let mine get low and my MPG dropped significantly. Once I slightly overpressured the tires, it went back up. Maybe not the whole answer for you but likely a part of it.
  9. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    I had a similar problem a little while back when I got my car back from the dealer but it was the 10k service so oil change was involved. To make the story as short as possible. They filled my car w/ 5 quarts of oil(the overfill is even stated on the invoice) which resulted in lower mpg. Also, the tire pressure on the invoice showed that they put it more to their spec but when I checked, it was the same as what I originally had it at. Obviously, I have some doubts in trusting the dealers as they can't seem to do a simple oil change properly:eek:.
  10. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    Someone pointed out that they may have done that for liability reasons to protect the dealership. Unfortunately, there doesn't seem to be any way around checking tire pressures when we get the car back from the dealership after service. And oil level.
  11. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Cindy, its not all tires and air pressure. Your 12 volt battery could be low since you just drive a short distance, the battery may not be charged enough.
  12. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    One thing I have noticed and check several times, If I refill to a full tank, and drive really careful, and get the mpg on CONS to 60+, then drive normally and watch the meter, I can have it hover about 51mpg. I have been stuck in that low 40's range, but that is missleading, you cant get out of that till you resteet the trip settings. When you shut the car off, look at the drive specs for mpg, you will see you got better than the CONS. It is a werid thing on the computer, its calculating, but what, who knows. It is all based on the first few miles where it sets its own metering. You gas it up a hill, you will never get it back to the 50's till it is reset, you will hover in the low 40's or worse. You nurse it to 62, and it will drop to about 52 or better.
  13. ES44AC
    ES44AC C.A.U.S
    319
    77
    My mileage went down too on my second fill-up. I can't for the life of me figure out why, unless it's because I decided to try and use ECO mode instead of NORMAL.
    Tire pressures are 38psi as they were with the first tank. That one seemed to last and last, but I didn't reset the odometer when I picked up the car so I don't know what the actual mileage was.
    Currently the tank is almost half empty and I have gone only 178 miles. I will admit that a lot of these trips have been very short ones with the ICE turning on more often. Of course I realize that uses more fuel but still, I am amazed at how fast this tank is disappearing.
    Can using ECO mode really make it drop like I am describing?
    When I first got the car I only drove it in NORMAL because I hadn't found this great forum and didn't know any better.
    Thanks to all
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    If you only have two tanks under your belt then I wouldn't worry about anything or try to draw any conclusions. You don't even know what your average for your commute should be. Eventually you'll figure out your average for each season, weather conditions, and your driving techniques. Right now you simply cannot say anything about the differences between Eco Mode and Normal Mode. Just drive the car for awhile. :)
    ES44AC likes this.
  15. danbirch
    danbirch Junior Member
    Canyon Lake, California
    I have found, consistently, that tire rotations and tire replacement ALWAYS lower mileage significantly (from 50+ to about 42). The mileage will then creep back to normal, after 1-2k miles. I have some doubts on the value of tire rotations, based on the cost, loss of mileage, and the additional wear on all 4 tires each time you rotate them. The other way, you change 2 tires at a time. The fronts will wear faster than the rears.
  16. bisco
    52,912
    unless they wear unevenly, then rotating might extend longevity.
    dorunron likes this.
  17. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    IMO since the front's do wear faster than the rear, rotating the tires will help to equalize the wear on all four tires and increase longevity of the entire set of tires.
    Ron (dorunron)
  18. danbirch
    If the tires are wearing uneven, you probably have another problem (struts/alignment/balance/etc.) Doing a rotation won't fix that problem. I do know, however, that many people believe in doing rotations. No big deal.
    #18 danbirch, Jul 26, 2014
  19. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    Running ac will def. dropMPG. DO NOT RUN WITH THE MAX PSI IN YOU TIRES. During the sumer months hot temps and hot pavement will increase you PSI in your tires. To much PSI will ruin your tires could cause a blow out. Rotating your tires every 5,000 miles will extend their life and should not affect your MPG. Running the correct recommended Psi in your tires will give you a smother ride and more traction on wet pavement.
  20. MattPersman
    MattPersman Member
    110
    33
    Indiana
    A person can run whatever PSI they want in the vehicle it is up to them to research what they think is best.
    bwilson4web likes this.
