Gas on to heat car - does it defeat the purpose
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by benalexe, Sep 16, 2012.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    As I said earlier, if the outside air is dry then point it towards the windshield.
  2. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Talking about "commutes" only is missing the point. Many if us have to take short trips to run errands, even though the commutes are longer.
    john1701a likes this.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Made it back home with 79 MPG, used up all EV miles.
    PiP was parked outside (9 deg F) for 9.5 hours. When I started, gas engine fired up like a regular Prius would. I checked if the cabin heat was on, nope. The battery was too cold to operate in EV mode but it was not in HV mode neither. It is in blended mode where ICE would be the primary power source and battery power would blend when ICE efficiency would not be hurt.
    I took the opportunity to defrost the ice built up inside the windshield. After that I left and once the ICE shut down after reaching operating temp, I was in the real EV mode.
    I turned off the cabin heater after a while so ICE would not come back on. I drove the rest in full EV, until battery depleted.
    I saw a Volt while I was in EV. His gas engine was running, looking at tailpipe. Not sure if he had cabin heat on or it was due to mandatory behavior.
    This is the first time I felt the heated seat at HI felt like it was on LO.
  4. El Dobro
    El Dobro A Member
    7,088
    3,270
  5. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    If you read the reviews of these heaters (except the Lasko, which is the 120 volt heater I mentioned above) you'll see that they are just inadequate to the task. I think it will take either a 120 volt heater/inverter setup, or a 12 volt heater that puts out at least 2500 BTUs of heat - and I haven't seen any of the latter type.
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    If you mean 2500 btu/hour I very much doubt you will, since it would require 60 amps.
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    And yet they are sized for the much larger 12 volt baterys of cars with a starter. Even these puny heaters would need a Prius in Ready.
    I think posters in this thread divide into those who understand how much electricity it takes to make heat, and those who want what they want, science be damned.
    markabele likes this.
  8. bisco
    51,944
    i'm no scientist, but from the 2 winter evidence on these boards, there is no current solution to this problem. did you see that one usb?:cool:
    usbseawolf2000 and markabele like this.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    What a great idea! I never thought about a usb operated heater. Perfect! :) I know right were to plug it in! :D I stayed at a Holiday Inn Express last night. Sweet!
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    USB can provide 2.5 watts of power. There are no 2.5 watt heaters, nor would they do you any good heating your car.
    retired4999 and markabele like this.
  11. bisco
    51,944
    i was talking to seawolf.:p
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I see a circuit board and current going through it.
  13. bisco
    51,944
    well said.;)
  14. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I think that you're mistaken. I spend more time explaining science to people here than I do anything else. What you mean is, apparently, "People who disagree with me are WRONG."
    I've elaborated more on how to build a 12 volt heater, with independent power supply, in the Leaf forum. I'll copy it here later. Constructive criticism welcome. As for the rest...does this software have a user filter?
  15. bisco
    51,944
    michael, i welcome your input and suggestions. please feel free to try something and report back here on the effectiveness. most of us are all talk and no action, but we'd love a cabin heating solution that doesn't fire the ice.(y)
  16. retired4999
    2,652
    627
    Eau Claire, Wi.
    +1 I agree! (y)
  17. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Thanks for the support. I'm going to start another topic with the rough outline of the heating system.
  18. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I think that if Toyota is going to relate to this issue (in next generation) it will be by a heat-pump rather than electric resistance heater.
  19. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    <--- Yes if you click on my Avatar, you will see an option to ignore me on the right. It will still let me leak in when others quote me, sorry.
    If you can't tell that a Leaf is a much different car than a PIP and has a much larger battery, it will be best to ignore me.
  20. markabele
    5,084
    1,782
    Nebraska
    That would only help down to about the mid-20s though right? At that temp and above a heavy coat and a seat warmer does the job. :)
