Gas only crusade
Discussion in 'Gen 3 Prius Technical Discussion' started by Andres V, Sep 27, 2018.
  1. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Yes that is it.
    Prodigyplace likes this.
  2. Mendel Leisk
    42,364
    Maybe some of the more knowledgeable hybrid battery rebuilders on this forum can comment, but I'm a little incredulous of this need to "reset the ECU": it's all based on hearsay from a single dealership?
    Attached is the battery replacement instruction from the Repair Manual, and it seems to be just that, no mention towards the end of resetting or replacing the ECU?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Not sure how the ECU fits into all of this. The easiest way to reset it is to disconnect the 12 volt battery and see what returns.
    If replacing a couple of modules, the ECU won’t know the difference.
    What codes are being displayed and how is it affecting drive ability?
    52,878
    it's driving fine, he wants to drive to houston.
    haven't seen any codes, maybe in one of his other threads
    Raytheeagle likes this.
  5. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    He is a bit all over the place:cool:.
  6. bisco
    52,878
    yep, see post #19 in 'realistic battery life' thread. P0A80
    but his big question regards the ecu
  7. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Meh, I just go by what’s in this thread ;).
    It’s a lot of work otherwise:cool:.
    Good to know someone’s keeping up though with all the threads and can keep em straight(y).
