Gas Prices
Discussion in 'Prime Main Forum (2017-2022)' started by huskers, Jun 25, 2017.
  1. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    I think it's California requiring this special blend; not the Feds. Only the refineries in the state and a handful of other out of state refineries have the capability to make this this blend, and it's more expensive to make. If there is a refinery mishap, the supply goes down and the price goes up. No new refineries are being built in California to meet increasing demand. I'd like to see an independent cost-benefit analysis on whether this special blend is worth it.
    California also enacted a carbon tax a couple of years ago, which raised the price of gasoline 11 cents a gallon. Why didn't they repurpose this money to fix the roads instead of raising the gas taxes?
  2. bwilson4web
    16,540
    jerrymildred and HPrimeAdvanced like this.
  3. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    you are correct on all counts, and just wait til Oct or Nov for the next gas tax increase - that is supposedly going to roadwork ... only time will tell :unsure:(n)
  4. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    $2.60~ seems to be about average for Western PA. That's okay though because our electric rates are super low. :)
    Prius from Dad likes this.
  5. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Yes I think the reformulated gasolines of the 1990's deserve a rethink. Among other things the 10% ethanol really makes a dent in MPG when you are in the 50+ range, not mention the lower energy content of the E0 portion of RFG. Cars are so much cleaner burning today, not sure what the optimum fuel is now.
  6. Prodigyplace
    12,717
    11,849
    Central Virginia
    Optimum for who or what?
    The vehicle, the consumer, business, or politics? :eek:
  7. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    The original reformulated gasoline was for reduced emissions/smog, based on extensive joint Auto/Oil R&D studies. Since then I think sulfur in gasoline has been reduced to ultra-low levels, which is probably the biggest factor (sulfur "poisons" the catalytic converter). So presumably if sulfur is really low, not sure some of the other EPA/CARB formula mandates are required now.
    Politics gets involved in the ethanol mandate obviously. One of the controversial findings of the old Auto/Oil study was minimal benefit of ethanol as far as cleaner burning, so eventually the justification for ethanol was changed to reduce petroleum imports.
    Prodigyplace likes this.
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    As I understand it, the ethanol requirement is all about rewarding corn farmers in the Midwest for their generous campaign contributions to Congress, even though making ethanol from corn is energy-intensive and not particularly clean. As opposed to specifying emissions targets that could be met in various ways, the rules were carefully constructed so that using ethanol made from Midwest corn was the only practical way to satisfy the rules.
    #28 CharlesH, Jun 26, 2017
    Lithium MPG and Prodigyplace like this.
  9. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Well back in the days (~1980) before catalytic converters, ethanol was well known to reduce CO in the exhaust. CO used to be like 8% (80,000 ppm - deadly) in auto exhaust before cat converters. Gasohol could whack that CO back like 30+% reduction, which was important in some cities eg Denver. So there was the feeling that ethanol helped, and that is why Congress was inclined to go along with the the corn lobby. But then when cat converters came out, CO is now essentially zero in Prius exhaust except when cold. So that's when Congress basically had to say they demand ethanol in the Clean Air Act for reasons other than clean air. Also we had an alternate (MTBE) for a ~10-yr time until that turned out to have eco-issues. During the Bush2 era, it seriously looked like we were running out of oil so everyone (bipartisan) was more supportive of alternates then. Since then a lot of huge changes in the energy picture.
  10. Jnbrown
    Jnbrown Member
    111
    85
    Encinitas, CA
    At 2,000 miles I have not bought gas yet for my Prime, but filled up my Sienna yesterday for $2.59 / Gal. I am one of those who does believe in buying the cheapest gas because I don't want to support the price gougers and yo-yo pricing, also I am saving around $4 per fill up. It so happens the cheapest gas is not far from my house and they basically track the price at Costco but without the long lines. If I am on the road using Gas Guru makes it simple to find the cheapest gas nearby.
  11. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Ethanol remains the least toxic way to raise octane and oxygenate gasoline.
  12. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...but one scientific point is we don't need to oxygenate fuel. The only reason to have an oxygen content requirement is to mandate ethanol.
    Anyways, back to price, I predict as low as $1/gal some places by Feb_2018. I was wrong this year 2017 due to the OPEC attempt to increase the price, but that was temporary.
  13. bluzfan35
    bluzfan35 Junior Member
    50
    55
    missouri
    Thats not even adding in there the cost of your time driving to get it. My time isn't free and wasting 20 minutes of time that i could be having fun is worth more then a couple of dollars in my pocket.
    JonW and Prius from Dad like this.
  14. bluzfan35
    50
    55
    missouri
    Got it for $1.88 today at work.
  15. MikeDee
    1,581
    597
    I read somewhere that the oil companies would still use alcohol even if there were no government mandate because it's the cheapest way to raise the octane level.
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    Yesterday I gassed up for $2.049/gallon. I could have gotten it for $2.019/gallon if I'd wanted to wait to make a U-turn, then make a right turn, then enter the station to fill up, then make a right turn out and try to get a U-turn asap, then wait for a left turn arrow so I could get back to where I was when I saw the lower price. Not worth it for 24 cents.
    jmarkd7 and HPrimeAdvanced like this.
  17. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Hey where's your sense of fun, Mr. Mildred!! You can't get a ride like that at Disneyland for 24 cents!!!
    jerrymildred likes this.
  18. jerrymildred
    11,517
    14,170
    Tampa, FL
    True dat!! Especially since, around here, they drive by ear rather than by sight. (BAM!! "Oops. Time to hit the brakes.")
    HPrimeAdvanced likes this.
  19. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Har, har!, Mr. Mildred that sounds like Bumper Cars; are you sure you're not in Disneyland!!??
  20. stevepea
    stevepea Senior Member
    535
    581
    For So Cal readers: something to keep in mind.
    On top of taxes and the normal fluctuation in gas prices, be prepared to pay at least 10c more a gallon soon. Remember that Arco (the low-price gas station chain, part of BP) has left the SoCal market due to BP's troubles after their terrible disaster a few years back. There are still Arco stations operating because BP doesn't want to throw money away breaking leases. But as soon as an Arco station's lease is up, it will close. Whether or not you like Arco, it is consistently at least 10c below other normal gas outlets (not counting membership stores). Many of the Arco stations that have already closed have turned into USA Gas stations, with an immediate average 8c raise in price, those that have turned into 76 or other higher-brand stations has gone up over 10c. The head of one of the chains buying a lot of the Arco stations when their lease is up was quoted a year or so ago in the paper basically saying "we're going to price ourselves where the rest of the market is, not where Arco has traditionally been." So as all the Arco stations slowly close over the next 5 years or so and turn into USA, 76, or other gasoline brands, expect prices (on top of all other factors) to increase by at least 10c/gal due to this. Luckily near me is one independent station that undercuts everyone -- it's super close, never had a problem with the gas quality, and is the cheapest by far. But as Arco leaves little by little, we're all going to be paying more.
