Gas Prices
Discussion in 'Prime Main Forum (2017-2022)' started by huskers, Dec 18, 2020.
  1. Trollbait
    12,806
    Oxygen sensors means the car can burn the E85. The amounts of fuel going in are out of spec from the gasoline fuel maps in the ECU, so the check engine light will come on. The injectors likely can't allow the full flow of E85 required at high engine loads.
    In addition to the long term potential harm to rubbers and plastics, the alcohol, more likely the water with it, can damage steel parts.
    The 2000 flex-fuel Ranger had larger injectors and stainless steel fuel system, in addition to ethanol compatible plastics, in comparison to the non-flex-fuel model.
    Merkey and Diemaster like this.
  2. Rmay635703
    Rmay635703 Senior Member
    2,688
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    Only flex fuel cars and my Cobalt, Volt, 2000 Honda Insight and a bunch of others.
    There honestly isn’t any excuse why we can’t use e85 in any modern car and it’s unfortunate they aren’t all required to be flex fuel given the distinct possibility we may need to run a naphtha + methanol mix in the near future given our lack of refineries. (Both are still about $1.50/gallon at bulk as far as I can tell)
    The difference between an e85 and non-e85 car of the same model is an ethanol sensor and a different fuel map, some cars like my Volt already have an ethanol map and need a $25 sensor.
    Long Gone are the days of FFV getting a unique fuel system.
    For all practical purposes I have found all 2001+ cars can run a half tank of e85
    Ethanol material compatibility is pretty much all or nothing, if it works with e10, it is also compatible with e85.
    It’s rarely been worth running e85 but at today’s prices I’ll run a half tank in all my cars.
    Worth noting bobwilson4web has Prius tests on e85
    #62 Rmay635703, Jun 9, 2022
  3. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    E85 will drop your gas mileage. Alcohol burns at about twice the rate as gasoline.
    privilege likes this.
  4. fuzzy1
    10,687
    When comparing and trading off different fuels, raw MPG is not the top metric of concern.
  5. bisco
    52,773
    what is?
  6. Trollbait
    12,806
    Some blends of ethanol and gasoline, in some cars, have had a better mile per btu efficiency than straight gas.
    Cost per mile.
  7. privilege
    privilege Active Member
    659
    169
    Birmingham
    huh ?
    which car gets better mpg with ethanol blends than pure, wonderful, gasoline ?
  8. MikeDee
    1,581
    597
    A gallon of ethanol has 30% less energy/btu content than a gallon of gasoline. The stoichiometric air–fuel ratio of ethanol is about 2/3 that of gasoline.
    There were reports on this forum of people buying/using 100% gasoline (E0) and getting better gasoline mileage. Of course the better mpg didn't offset the higher cost of it.
    If everyone could switch to E85, there wouldn't be near enough of it to meet demand, and the price of it would skyrocket too. Not a solution to the problem.
    #68 MikeDee, Jun 9, 2022
  9. Trollbait
    12,806
    The combustion reaction in an ICE is a complex one. In the 30% to 40% range of ethanol, some cars managed to turn a higher portion of the reduced energy content into motion than the cars running straight gas. I can't say why. Maybe the cooling effect of the ethanol improved engine efficiency, or that engine could make better use of the higher octane. Could be multiple reasons.
    An engine made for E85 would be more efficient than the low compression gasoline engine that simply gets a different ECU program. Just using a higher compression one for flexfuel cars would have netted better results.
  10. fuzzy1
    10,687
    Cost per distance is one already mentioned, carbon (or just fossil carbon) emitted or crude oil pumped out of the ground per distance traveled would be others.
    If MPG was the sole metric, nobody would use E10 / E15 / E85 due to their lower scores on that metric, even though they score better on those other measures. Or possibly could do so, depending on just how the other components are produced.
    Trollbait likes this.
  11. MikeDee
    1,581
    597
    Higher compression means thermodynamically higher efficiency, but higher combustion temperatures and the result is higher NOx emissions. I don't think you can go there with emissions regulations being what they are.
  12. Rmay635703
    2,688
    1,725
    2013 Chevy Volt
    15-30% more for me
    $3 x 1.30 = $3.90 worst case, still saves money over e10
    Now methanol is twice but it’s $1.50 a gallon
  13. Trollbait
    12,806
    The majority of cars are now high compression direct injection. It's how ICE cars have been improving their fuel economy. With the higher ethanol blends, the alcohol's evaporative cooling effect can lower cylinder temperatures.
    I'm not calling for a switch to ethanol. I'd like to see other alternative fuels have a chance. But if we are going to use ethanol, let's make the best use of it.
    Rmay635703 likes this.
  14. MikeDee
    1,581
    597
    What's the highest alcohol/Exx content you can run in a Prime, according to Toyota? Of course, I'm averaging 125 mpg with charging the car, so even with the high price of gas, I'm not buying that much of it.
    Brazil probably did the most with biofuels. It never got close to replacing gasoline. Read the Wikipedia article. No way we make enough here to get even close to what Brazil did/does, and they use sugar cane instead of more expensive corn to make ethanol.
  15. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    15% ethanol MAX. In my region almost all regular gas contains 10% ethanol. It is very hard to find anything higher or lower. Although there have been some stations stated to carry ethanol-free premium gas, I have never seen any gas station that carries E30, E50, or E85.
    Merkey and Rmay635703 like this.
  16. Rmay635703
    2,688
    1,725
    2013 Chevy Volt
    We still burn off and loose 30-40% of natural gas production due to “not being economical to recover “
    We shouldn’t realistically allow NG to be burnt off directly from all the Dakota wells and instead make methanol on site in the remote areas, reforming NG to methanol is simple and cheap, could then start dumping a small percentage of methanol into pump gas offsetting ethanol for other uses.
  17. privilege
    659
    169
    Birmingham
    which cars ?
  18. Trollbait
    12,806
    The study I was thinking about was an old one. IIRC, the Ford(flexfuel and regular) and Toyota models took advantage of the increased ethanol content, and the GM's did not. This was before direct injection came back to the market.
    The reported study here looked at flex-fuel cars. Study Finds That Higher Ethanol Blends Result in Improved Energy Efficiency in Flex-Fuel Engines, Partially Offsetting Reduced Energy Density of Fuel - Green Car Congress
    Plenty of studies doing direct testing with small engines in a lab. This one is preprint, but was the first I found that looked at ethanol concentrations above 20%. https://www.researchgate.net/publication/349405751_Effect_of_Ethanol-Gasoline_Blends_on_SI_Engine_Performance_and_Emissions
  19. MikeDee
    1,581
    597
    audiodave likes this.
  20. bisco
    52,773
    good on them :)
