Gas smell only when full
Discussion in 'Gen 3 Prius Technical Discussion' started by Tha_Ape, May 12, 2021.
  1. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    So I've noticed this for the past year or so (we dont fill up that often). Whenever our (2010) Gen3 is full, the garage will reek of gas until we've driven it and burned off a couple of gallons. This isnt from spillage at the pump, because if we dont drive the car for a few days, it still smells. It's easily repeatable and always goes away when the gas level drops.
    A couple of weeks ago we filled up and had the smell, then over a few days drove it 60mi or so and the smell was gone. Then, in preparation for a weekend trip, we topped it off... sure enough, the gas smell came back. The smell gets into the cabin if we leave it in the garage, but I dont think its coming from inside the cabin. Thats just an effect of being in the garage. We just park it outside and its fine... no smell inside the car.
    My theory is that the filler neck needs to be replaced, because the smell goes away after a gallon or 2 of gas is burned away, but I wanted to reach out to the community and see if anyone else has had that problem on a Gen3 (or other car). I obviously could take it to the dealer, but I dont have much faith in my local dealer, and I dont mind working on my car myself.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    You should never "top it off".
    The problem likely is that overfilling has forced gas into the evaporative emissions control charcoal filter canister.
    That can also cause it to run a bit rough when full sometimes.
    That evap system needs to be cleaned out and hoses checked.......or the canister replaced.
    Possible that the filler neck has gone bad.....or there is a loose joint......but highly unlikely.
    Ozark Man likes this.
  3. ETC(SS)
    7,452
    ^ That.
    It's also possible that a former rear-end collision may have knocked something askew....or as mentioned above something in the Evaporative Containment system is causing the problem....but yeah.
    99.44% of the time this is caused by over filling either because the driver is doing it or the pump itself isn't shutting off in time.
  4. Tha_Ape
    271
    162
    Washington, DC
    I should clarify, "Top it off" meant fill it up until it automatically stops. I dont mean going beyond when the hose clicks and keep on pumping.
    In this particular case, I meant going from 3/4 to full tank as "topping it off"
  5. Tha_Ape
    271
    162
    Washington, DC
    I WISH I'd been rear ended... we've had this mark on the bumper caused by a cyclist leaning against our car and pedaling away (left a big gash) 2 weeks after we got the car years ago. been waiting to replace the bumper cover. where I live the chances of getting rear ended are high. been tapped in most of my cars... somehow this one has lasted a decade without a tap.
    I'll check out the evap system. This isn't a particularly new issue and we've filled up at multiple stations over the years so it's not the pump and it's not us going past the limit.
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    It only has to happen once. The gas stays in that canister for a LONG time.
    And how many different people comprises "us" ? :)
  7. Tha_Ape
    271
    162
    Washington, DC
    Only 2. But it doesnt smell like gas after driving the car for 50mi. Then no more smell for months... it sits in a the garage with occasional use and 0 smell... UNTIL its refilled.
    So whatever the problem is, it is dependent on the amount of gas in the tank. If its 3/4 full or less, never smells. Once its full, reeks. Even if left outside for a week, if its full and we put it in the garage, it will smell. Once a few gallons are burned off, we can put it in the garage and it never smells.
  8. Tha_Ape
    271
    162
    Washington, DC
    Fixed - it was a crack in the fuel pump assembly case. Turns out you have to replace the whole thing. Even though the pump/filter/gauge all work. Bummer!
    Henrik Helmers and Mendel Leisk like this.
  9. Mendel Leisk
    42,182
    Plastic I’d assume?
    Tha_Ape likes this.
  10. ETC(SS)
    7,452
    Isn't EVERYTHING?
  11. Tha_Ape
    271
    162
    Washington, DC
    yea, I actually was going to play with it, the mechanic had it sitting on the side, but as you can imagine, it reeked of gas. The cracked part was just the upper rim, too.
    I decided I would sell the car, but didn't want to sell it smelling like gas. I could have been shady and just had the tank 1/2 full when selling it, but that's not my style.
    I was a great car, but we don't need 2 Priuses. We almost always drive the Prime unless we need the capacity (home depot runs).
    I did feel like closing out the thread though. I hate when I search the web, find someone with the same problem and then no resolution
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    OMG. A person who actually has a good sense of RESPONSIBILITY. :eek:
    A pretty rare find these day.
    (y)
  13. ETC(SS)
    7,452
    Maybe not as rare as it might seem these days, but noteworthy nonetheless.
  14. ASRDogman
    ASRDogman Senior Member
    7,976
    4,049
    You don't NEED to have 2 Prius' to HAVE 2 of them. :whistle:
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    That's how I feel about motorcycles !!!! (y)
    OK, used to.
    Riding on 3 wheels now.
    Getting old is a bitch.
    Tha_Ape likes this.
  16. Tha_Ape
    271
    162
    Washington, DC
    I bought the Prime because the 2010 was so reliable. Have had that Prime for 2 years (its 4yrs old) and no issues either. Toyota makes great cars
  17. ETC(SS)
    7,452
    Beats the alternative.....
  18. ASRDogman
    7,976
    4,049
    Wait till you hit your 90's......
  19. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    if it was that reliable, you wouldn’t need to buy another vehicle :LOL:
    ASRDogman likes this.
  20. Mendel Leisk
    42,182
    We were talking in passing to an couple, perched on the shady side of a transformer foundation, about how a lot of people use it as a bench*. The lady quipped “When you’re ninety everywhere’s a bench”. :)
    * Coquitlam, aka Drive-thru Ville, home of full-serve-only gas, and bereft of benches (and garbage cans, and don’t even about public toilets).
