gas tank
Discussion in 'Gen 2 Prius Main Forum' started by larrydodge, Jul 30, 2020.
  1. larrydodge
    larrydodge New Member
    Selkirk, New York
    2008 prius engine light , mechanic says need new gas diverter valve but part only comes with new gas tank at a price of 998.00 ( for labor & parts). True?
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    In general it's less expensive to replace the whole tank, but a 13 year old car is not worthy of brand new overpriced parts. Find a mechanic that will install a used gas tank system or DIY it via a wrecking yard.
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    Did the mechanic use an OBD2 scanner to retrieve the codes (DTCs), and can you post them here?
    Post the replacement part # and we can help you locate the best price for a new or used option as well.
    srellim234 likes this.
  4. larrydodge
    Selkirk, New York
    thankyou! will do the used tank if need be, so far mechanic says can drive it safely but the light will stay on.
  5. PriusCamper
    13,467
    5,434
    Yea... There's many stories I've heard of people driving for years with warning lights on and without any problems... However if a new problem develops, you won't have warning lights that turn on because they're already in use by the other problem, so that could be problematic in the future.
    SFO likes this.
