Gasoline additives needed if Prius Prime is mainly driven in EV mode?
Discussion in 'Prime Technical Discussion' started by Klamil1899, Jul 1, 2019.
  1. Klamil1899
    Klamil1899 New Member
    2019 Prius Prime
    I bought my 2019 Prius Prime Advanced about 2.5 weeks ago, I barely use any gasoline between work and home, I still have the full tank of gasoline that was filled up during the purchase. My estimate: One tank of gasoline may last for 4-6 months, do I need any gasoline additive to protect my car?
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    If you stick with one of the "Top Tier" brands of gasoline and burn a tank a year you'll be just fine.
  3. Prodigyplace
    12,712
    11,848
    Central Virginia
    If you are concerned you could add some Sta-bil fuel stabilizer.
  4. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    No. The tank is pretty much a sealed system and the fuel won't suffer in 6 months. And, when you need to refuel, just put in 3 gals at a time until just before you head out on a road trip, then fill it.
    I came back from a road trip on May 16 with about three bars on the fuel gauge, and yesterday (June 30) I put 3 gals in. That's 1205 miles, probably 400 on the road trip and the rest since then.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    But make that "some" read "the recommended amount".
    Then put in more stabilizer ONLY as the tank full is pretty much used up.
    Too much stabilizer can cause troubles too.
    Most people in most situations do not NEED to put in any "fuel additive".
    The car is programmed to not let you drive around with the same gas in the tank for a year or more.
  6. bisco
    52,840
    congrats and welcome!
    i have never added anything to my gasoline. what kind of additives are you talking about?
  7. Rmay635703
    Rmay635703 Senior Member
    2,699
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    I would do whatever the manual says,
    but Generally no OEM will list gas additives, they simply aren’t useful on a modern car
  8. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    The Prime isn't like a 2-cycle gas lawn mower. As long as you burn through the gas once a year (as noted in the manual), no additional additives are needed.
    However, you may consider using up some of that gas so that it isn't 4-6 months of dead weight, bringing down your EV efficiency.
  9. MSantos
    MSantos EcoAccelerometry
    589
    260
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    And then you have weird people like me who almost a year and a half later (and over 9K miles on the clock) still have 1/4 of the original dealer tank to go. Perhaps an extreme when compared to the broader demographic of prime users but so far no issues to report.(y)
    Cheers
    jerrymildred and walterm like this.
  10. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Just curious - why did you buy a Prime instead of a BEV?
    kevin.c likes this.
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Signature says they have a Model S so maybe the Prime is for trips to places with no chargers in the great white north. Just a guess.
    Prodigyplace likes this.
  12. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    If that were the case, then you would not see 3/4 of a tank used in 9K miles. Any long road trip in a Prime is going to burn mostly gasoline.
  13. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    How does the Prime know the length of time gas has been in the car?
  14. Tideland Prius
    16,678
    Probably looks at the last time the gas tank was depressurized.
    noonm and Prodigyplace like this.
  15. MSantos
    589
    260
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    Because the Prime is the closest thing to a Toyota BEV one can buy in North America. Having a fair bit of experience with BEV's in my part of the country also allows me to appreciate the more subtle qualities of a car like the Prime. Super dependable and reliable. And definitely the most efficient given my location and usage which makes it a worthy daily driver instead of just another weekend toy.
  16. Rmay635703
    2,699
    1,729
    2013 Chevy Volt
    The volt monitors the exact fuel level and when you fill calculates the average fuel age.
    My guess is Toyota does something similar monitoring the fuels age so it gets burned off occasionally
    fuzzy1, Prodigyplace and Marine Ray like this.
  17. fuzzy1
    10,705
    On-board clocks and computers.
  18. Tideland Prius
    16,678
    You’re giving Toyota too much credit. ;) We’ve been asking for oil life meters and the such since the 2nd gen Prius.
    I wouldn’t be surprised if it’s a simple mechanism such as fuel filler door release or the fact the fuel gauge hasn’t moved (not necessarily the exact fuel level).
    Anyway, the manual says add 20L per 12 consecutive months if you don’t use it. (So basically, try to use half a tank a year :D).
  19. fotomoto
    5,639
    3,815
    So. Texas
    I'd hope it's not that simple as that would be too easy of a hack for those (few) who refuse to buy gas. I inadvertently pop open the fuel door on my PHEV's while cleaning the dash with a large rag as I sweep across all the buttons.
    My guess is it would have to be a combination of the fuel system depressurization and gauge level changing.
  20. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I would use all the fuel additives mentioned in the owners manual: None.
    Curlyone, jb in NE and Rmay635703 like this.
