Gasoline brands
Discussion in 'Gen 2 Prius Main Forum' started by Twiddles, Nov 29, 2005.
  1. Citgo
    0 vote(s)
    0.0%
  2. BP Amoco
    0 vote(s)
    0.0%
  3. Chevron/Texaco
    0 vote(s)
    0.0%
  4. Shell
    0 vote(s)
    0.0%
  5. Sunoco
    0 vote(s)
    0.0%
  6. Getty
    0 vote(s)
    0.0%
  7. Hess
    0 vote(s)
    0.0%
  8. Exxon/Mobil
    0 vote(s)
    0.0%
  9. Other
    0 vote(s)
    0.0%
  10. Unbranded
    0 vote(s)
    0.0%
  11. Whatever is cheapest- it's all the same
    0 vote(s)
    0.0%
  1. samkusnetz
    samkusnetz New Member
    85
    Portland, OR
    fwiw, BP is the only gasolene brand which makes a point of informing the public about their alternative fuel research. as far as i know, they are the only company that is publicly commited to alternative fuels, which i think meshes perfectly with the green attitude of the prius.
  2. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    Tough choice between “Whatever is cheapest†and “Other†since I mainly purchase my gas at Costco. :)
  3. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Well the last time I tested it was between BP gas and Arco...Arco was 3mpg less.. but that was with a car that only gets 18mpg... so convert that to what a prius would do.. it should be around 6mpg or more difference.
    In my area I usually get Safeway gas or cheveron. Cheveron often beats safeways price!.... safeway only gives 3 or 6 cent discount based how much food you buy.
    the way the prius gets such good mileage.. a little bit of gas efficiency, goes along way when your up around 50mpg or better!
  4. Catskillguy
    Catskillguy New Member
    536
    Mid Hudson Valley NY
  5. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    So how many of you that claim all gasoline is the same and just by the cheapest are getting 60 plus mpg tanks? I'd be surprised if many of you are getting over 50.
    I know I can't without the right gas.
  6. windstrings
    6,280
    378
    Central Texas
    Does anyone know what Safeway uses?
    Besides California, is it obvious to tell if a station has alcohol in thier gas?.. will it always be labeled Ethanol?
  7. aaf709
    3,862
    2022 Prius Prime
    Interesting. In CA, at least, Arco is owned by BP. I presume that it's the same elsewhere in the US.
