Gasoline Density Study - Started
Discussion in 'Fred's House of Pancakes' started by wjtracy, Feb 6, 2014.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Don't try this at home, but in another thread I had resolved to get a few gasoline samples to study energy content (weight) per gallon, and how it varies. I recently realized winter gasoline here in north VA (EPA reformulated gaso E10) probably represents the low density extreme (high RVP season), so that meant I needed to get started.
    Method:
    All you really need to do is: pump exactly 1-gal into a can based on the gaso pump meter and measure weight and temperature of the fuel sample. I used a red plastic 2.5-gal safety container. I filled the red safety container with 1.0-gal after I first filled my car. I tried to use a hand-held infrared meter for container temp, but had trouble getting exact reading. Got 2786 gram net weight at 40 deg F approx temp.
    Prelim Result: 0.726 g/cc at 60 deg F (with temp adj) Regular E10 RFG NoVA
    Wow that sounds like a pretty low density measurement! and low energy content, as I was expecting for winter RFG E10 , Regular grade. I am expecting to see 7-10% higher density (and thus MPG) in summer and outside my EPA RFG region and for Premium. I double checked volume and it seemed to be exactly 1-gal. I tried to utilize proper safety precedures.
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    [quote="wjtracy, post: 1958242, member: 17892"I tried to use a hand-held infrared meter for container temp, but had trouble getting exact reading.[/quote]
    I am not surprised. They work mostly only on opaque things within a given range of emissivity.
    You could let it sit in the can for a while, and measure the temperature of the can.
