Gasoline Engine Starts Then Stalls After 10 seconds or so
Discussion in 'Prius c Technical Discussion' started by ugabuga, Jan 30, 2017.
  1. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Sometimes "snarky" is an appropriate response......like in this case.
    And I think the first thing to do is a thorough inspection, looking for things that are damaged or disconnected.
    But if you aren't familiar with the model, that might not be effective either.
    And he doesn't seem to want any of my advice so ........I quit.
    Good luck.
  2. ugabuga
    ugabuga New Member
    TOmato Land
    2014 Prius c
    another not very helpful post. I din't understand why you would waste your time typing all that.
    What cars I buy is my personal choice.
    I asked specific questions, which doesn't matter what the car is - car shuts off. Have you expereienced it before. Yes or no .If yes tell me what the experience was. That's i t full stop.
    Also I asked about the emergency shutoff system.
    the only useful response was the reference to the techstream software.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Never said it wasn't. But when asking for evaluation and advice in a public forum. Full disclosure about it being a Salvaged Vehicle should be part of the revelation about the state of the vehicle.
    Uh...no. The fact that it's a Prius and a Hybrid, really does matter.
    My speculation is that is it not the emergency shut off system...because the emergency shut off system is designed to "shut things off"". Which means you wouldn't be able to start the engine and then have it stall...But this is a speculative guess.
    Yep, and I agree that's a good place to start.
    Good Luck with your Salvage Project.
    Do keep us updated.
  4. Sam Spade
    2,036
    1,023
    2017 Prius c
    Right back at 'ya. Pot, kettle, black.
    P.S. A couple of us are trying to help you by giving you pointers on improving your communication skills.
    If you would LISTEN instead of flying off the handle, maybe it actually WOULD help you some. Maybe.
  5. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    It takes two to sustain an argument. Whoever backs out gracefully is the winner, IMHO.
    Raytheeagle and Mendel Leisk like this.
  6. Sam Spade
    2,036
    1,023
    2017 Prius c
    Yes I know. :(
    But it is SO HARD sometimes. :mad:
  7. ugabuga
    ugabuga New Member
    TOmato Land
    2014 Prius c
    so a quick updates for the haters - with the help of a VCI cable, techstream, TIS subscription and some elbow grease the car is fixed and running great.
    For those that actually want to know what happened - it didn't require any of that technology although it helped to ascertain that everything was basically ok. ECU complained that the engine was producing less power than expected. Turned out to be a crack in the intake manifold in a place that is hard to see - essentially a very large vacuum leak.
    Hope this helps someone
    Got2bHam and Mendel Leisk like this.
  8. Mendel Leisk
    41,463
    Worthwhile hooking up a vacuum gauge then. I've got one kicking around, forget I even have it though. I wonder if there's a spare vacuum spigot readily available? If not you could use a T-connection, tap in to another vacuum line.
  9. Sean Nelson
    421
    182
    Very interesting - thanks for the follow-up. How much effort / cost is it going to be to replace the intake manifold?
  10. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    So no specific flags for a vacuum leak? What DTCs were on the engine ECU? (Or perhaps P3191 the only one that showed)
    And no accident battery lock out, I gather. Good show! (y)
  11. Sam Spade
    2,036
    1,023
    2017 Prius c
    How do you define "haters" exactly ??
    Maybe I am one; it upsets me when people post what they think is good information when it really IS NOT.
    Your post told us basically NOTHING useful.
    If "the fancy technology" wasn't really needed, then what exactly DID point you to the source of the problem ??
  12. Got2bHam
    Got2bHam Member
    155
    51
    Missouri
    Glad you found the problem! Trouble shooting is half the battle.
    Raytheeagle likes this.
