Gear Shift Keeps Returning to N
Discussion in 'Gen 2 Prius Main Forum' started by nbullock, Jun 24, 2009.
  1. nbullock
    nbullock New Member
    IL
    This has happened 2 times in the last 2 days, after sitting in the 97 deg heat all day. I cannot shift to D or R, it keeps going back to N. I have made sure that door was closed, I have applied the break, turned the power on, waited for ready light. I got a ride home with a friend then returned the next morning and it was fine. Then not fine after work. I was able to drive it a bit while holding it in D.
    Has anyone heard of resolution to this?
  2. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    Yes, I've heard of two or three instances. It could be either some debris within the shift mechanism that needs to be cleaned out or the mechanism needs to be replaced. See this for more.
    2 people like this.
  3. nbullock
    nbullock New Member
    IL
    Thanks - I will be happy, if that is all it turns out to be. It is working fine today.
  4. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    To me that would suggest that the sensor that detects that the stick has been shifted over to the left is reporting that it is shifted over when it isn't. This could be the sensor itself, or a wiring problem.
    There are two sensors - one detects horizontal movement and the other vertical movement.
  5. Patrick Wong
    18,200
    6,479
    I agree that replacement of the shift mechanism is the likely fix.
    With my 2004, when shifting into D I have recently noted a new clicking sound. So I will probably have to replace the shift mechanism in the future, anticipating the click is an indication that the bearings are about to fail.
  6. lucky1
    lucky1 Member
    145
    61
    Ontario
    I had a wire they call a spiral wire that went on one of my taxis.
    The card would pop into neutral at a stop light and I would have to power off and power on again to get the car moving until I had to stop again and it would go to neutral again.
    The wire was $400 Canadian. The car had been in an accident 2 months earlier so I assume that is what eventually led to the wire shorting out.
  7. Patrick Wong
    18,200
    6,479
    I experienced the opposite problem that the OP described: the gear selector remains in R or D when moved to those positions. Apparently the spring that pulls the lever back to N has broken. I just noticed this when taking my 2004 to the body shop this morning for repair to the two driver's side doors (which were hit last Thursday). While the selector is in R or D, you cannot shift into P.
    I ordered a new shift lever assembly from Champion Toyota, Houston for $287 plus freight. I'll post instructions on how to replace this part after I receive and install it.
  8. Qlara
    Qlara New Member
    488
    That would be suck if this Shift-Lever switch tends to fail over time or under hot/cold in a prolonged period.....
  9. mfa-prius
    mfa-prius Old member
    299
    45
    Hansville, WA
