Gen 1 2002 CEL OBDII Code P1636 HV ECU Malfunction
Discussion in 'Generation 1 Prius Discussion' started by DRACO, Nov 29, 2015.
  1. S Keith
    S Keith Senior Member
    799
    330
    AZ
    2003 Prius
    I'm going to give an opinion somewhat contrary to Bob's. NiMH chemistry detests charging at high rates when cold. I expect the car will protect against this, at least I hope it does, and I know 100% for certain that Honda IMA does.
    Below about 40°F, charging should be limited to only a couple amps. Charging first thing in the morning in a lot of parts of the country will be a problem. Below freezing, charging should be limited to 650mA.
    Optimal charging occurs around 70-80°F as the charge efficiency is near 100% up to 70% SoC particularly with such low IR cells. When charge efficiency is that high, very little heat is produced. When you drive higher than 70% SoC, you start to get more and more heat as you approach 100% SoC. The car will obviously not allow this and stay well within the "near 100%" charge efficiency range, AND it will continually taper the current as you approach max SoC
    Heat isn't the enemy. Excessive heat is the enemy. NiMH works extremely efficiently up to about 100°F and even higher. At about 115°F inefficiencies start to manifest themselves.
    I understand the motivation to treat them as gently as possible, but they are extremely robust and the car uses them pretty aggressively. IMHO "Gentle" testing may not yield an accurate representation of the SoH of the battery. "Gentle" loads from the car's perspective are 20-30A - these are what I have observed with very "gentle" driving while monitoring with Techstream.
  2. bwilson4web
    16,537
    Living in N. Alabama, we have different concepts of cold. It feels a little above 70F on Christmas Eve so I will defer to those Nawth of here.
    The OP data was in the mid 30s C and that was a bit too warm for my tastes. Closer to 15-25 C would be cold enough for our testing.
  3. S Keith
    799
    330
    AZ
    2003 Prius
    Mid-30's... That's where my temps were on my discharge test. NiMH is really happy around there.
    On the Gen2 discharge test, the peak was 48.8°C :)
    Even here in AZ, cold can be a factor.
  4. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    Update Christmas Day Test:
    Could not find traction current so I picked WIN and WOUT :-/
    70%
    Also in reverse "R" I was monitoring it until 52% SOC then it suddenly dropped to 35% :-o
    52%
    34.5%
    Stabilizing prior to Shut Off
    Fan was on.
    #64 DRACO, Dec 25, 2015
  5. S Keith
    799
    330
    AZ
    2003 Prius
    Unfortunately, you needed the IB Main Battery field to capture current. Is the file you attached a .CSV file renamed as ZIP? It appears to be an excel file with an incomplete data conversion. Please confirm. If you did anything with the CSV file, could you post the original?
    BLock 16 was on the verge of giving it up at 52%. 13.2V is a "danger zone" level for discharging a 12 cell NiMH, so you probably hit it and the BCM choked it down to < 40% SoC.
    bwilson4web likes this.
  6. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Ah Poop
    Will do it again.
    As far as the zip file
    I did the same thing as last time
    Just saved file from cvs to zip file type
  7. S Keith
    799
    330
    AZ
    2003 Prius
    Drop:
    WIN
    WOUT
    Delta SoC
    Battery inside air temp
    Aux battery voltage
    ADD:
    IB Main Battery
    Battery Blck Min Voltage
    Min battery block no
    Battery Blck Max Voltage
    Max battery block no
    Here's your min/max plot:
    Here's all the blocks:
    Zooming in:
    shows blocks 16, 17 and 10 as the weakest. Most of the rest are in a cluster.
    13.29 BLK16
    14.09 BLK17
    14.35 BLK10
    14.52 BLK7
    14.54 BLK14
    14.56 BLK8
    14.56 BLK9
    14.57 BLK5
    14.58 BLK11
    14.59 BLK6
    14.60 BLK4
    14.60 BLK12
    14.61 BLK13
    14.63 BLK3
    14.63 BLK15
    14.70 BLK2
    14.78 BLK18
    14.86 BLK1
    14.97 BLK19
    DRACO likes this.
  8. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Outstanding!
    Will redo the test
    Thank you Brother Steve :cool:
    BTW, when I did the static test with the DVM those three blocks were the ones with the weakest cells 7.4-7.7 volts
  9. S Keith
    799
    330
    AZ
    2003 Prius
    That's confirmation!
    Doh... forgot the visual...
    DRACO likes this.
  10. bwilson4web
    16,537
    Expect to replace modules:
    • Both 32, 33, 34 and one of either 20 or 21
    S Keith and DRACO like this.
  11. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Lucky, I ordered 1 more so total of of 4 modules :love:
  12. racerx944
    racerx944 Junior Member
    16
    LA, CA
    2002 Prius
    I
    I have a few gen I modules that are good and from a running car after I sold off my extra modules. if you ever need anything in the future. I am near Carson so I am probably 15 minutes away from you in RPV. For the guys really helpful guys on this forum who regularly contribute to help others (Patrick, bwilson, Keith, etc), if you guys ever need any parts for testing or experiment purposes, you guys are welcome to borrow and use my parts. I have several spare transmissions, a spare motor, several inverters, etc for the gen 1.
    I always wondered if a transmission can be paired with an 110v external motor to make a charger for the battery packs...
  13. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Oh very cool.
    Just may take you up on those cells!
    TIA
    Jim
  14. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Just received:
    4 newer used cells all at 8.00 volts
    New Front Bus Bar with Sensors
    Used Corrosion Free rear ground strap.
    Installing Monday, MIL excited :D
  15. Ola2die4
    Ola2die4 New Member
    Nigeria
    2002 Prius
    I
    Hello Every 1 i am having a whole lot of trouble fixing my prius 2002 1 gen, its giving me P1636, have tried everything in the book it isnt working pls help out with any positive solution am really confused DIY
  16. Ola2die4
    Ola2die4 New Member
    Nigeria
    2002 Prius
    I
    I have a P1636 i dont know what to do pls Patrick Wong or any one pls advised
  17. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    It's a communications error between the ECU and the HV-ECM. Here's the diagnostic:
    [​IMG] You can click it for a larger version. Sorry for the poor scan quality, but the all the text came through. I guess first thing I'd check would be the harness connections at the ECU and the ECM. Might be dirty or loose contacts.
    BTW, welcome. You will do better here if you feel free to start a new thread with your questions.
  18. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
