Gen 1 2002 Prius P1636 Triangle won’t start
Discussion in 'Generation 1 Prius Discussion' started by CommanderVitaly, Apr 30, 2021.
  1. CommanderVitaly
    CommanderVitaly New Member
    Philadelphia
    2002 Prius
    Ok so the cars battery HV battery would sometimes not be working and started not turning on 100% of the time, but the car would drive, then it started driving with the loss of power, I would press the medal and it wouldn’t move then would jolt and move, the screen flickered sometimes when it happened, then the car would not completely start. I had to drive places so I would turn the key and immediately jerk it to reverse or drive and it would start up. Then it stoped working altogether, code P1636 and ready light wouldn’t come on, when I would reset the computer still nothing. Sometimes I would take the 12v battery positive and take it off and put it back on and the car would start sometimes. But not it will not show ready light for nothing, my dad took out the hv battery and saw some corrosion, he changed some of the bad batteries and cleaned everything back up and we put it back on so now I know the battery is good, it’s just uncharged because it say 2 weeks, I bought a need battery and battery plus terminal, so the 12v is good to, the car will not clear the P1636, amd I don’t know what it can be please somebody help. What could be the problem to why it won’t start? I bought an elm327 car adapter and paid for torque app but I couldn’t figure out any PIDs and don’t really even understand how that would help me solve this issue, I’m really not the best Mechanic and my dad isn’t the best with electronics, the shop wants 125$ an hour. Can anyone please give any solutions and I’ll let you know if we’ve tried it.
  2. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    P1636 means that the main engine computer (ECM/engine control module) and the HV computer (HV ECU) are having a communication problem. ("When [ECM] communication with HV ECU is interrupted for 1.5 sec. or more").
    So it's likely because one of those computers has a problem, or the wiring harness/connectors have a problem. My guess would be the latter. The HV ECU is inside of the battery case. I'd start by a simple visual inspection of the harness connector there. The ECM, I believe, can be accessed behind the glove box. I'd next do a visual inspection there.
    You're not a mechanic and dad's not great with electronics. Does anyone at least own and know the basics using a digital voltmeter?
    And just because corrosion was cleaned up in the HV battery case doesn't mean it is good. Does the elm read the HV battery data? If not, look up the Dr. Prius app. Or if you want to get ambitious, search here for getting a "mini-VCI" Techstream knockoff.
    #2 Josey, Apr 30, 2021
  3. landspeed
    landspeed Active Member
    387
    210
    NZ
    2003 Prius
    Hi!
    Your story sounds maybe like you *might* have a ‘bad high voltage battery’ - that can usually be fixed quite easily. The high voltage battery is around 300 volts - and 50 volts can be fatal. So - caution is required around the high voltage battery.
    The errors where one computer can’t speak to another - that is usually the 12 volt battery being low voltage / flat (some computers don’t boot up). It is in the boot of the car, in the left hand side. The 12 volt battery should be at least 12.5 volts when you check it when the car is ‘off’. You can use a normal car battery charger on that (because it is a normal car battery). It should be charged outdoors (the car outdoors or good ventilation if in a garage, or charge it during the day using a normal 12v car charger (buy the slightly more expensive ones with multi-stage charging).
    - Today I took my Gen 1 Prius for the first government check since I owned it; most people take their cars to private garages - but this was an official testing station!!!!
    —- I bought the car in December 2019.
    —- in April 2021, The 12v battery was dead, I charged it up but it needs to be replaced. Today I got : ABS error, airbag error, battery error, hybrid system failure - all due to a partially dead 12 volt battery!! After charging the 12 volt battery (and disconnecting the battery for 30 seconds (30 seconds is fine, but try 5 minutes if the errors keep recurring).
    Your story also sounds like the ‘inverter pump’ has failed. This makes the inverter slowly overheat - and this causes problems, including the 12 volt battery going flat (the inverter ‘inverts’ a 12 volt supply to charge the ‘12 volt normal car battery) - the inverter can shut off if it is overheating.
  4. landspeed
    387
    210
    NZ
    2003 Prius
    OK I read you have a new 12v battery - which is good!
    A basic multimeter will allow you to check the 12v battery voltage; it should be at least 12.0 volts, and between 13.7 and 14.5 volts when the car is powered up.
    you need to check the inverter coolant pump - it is easy (YouTube link in next post);
    Your ‘high voltage’ battery can still be faulty - even if cells were changed - that probably is one problem with your car - which can be fixed, after simple testing using a basic multimeter.
  5. landspeed
    387
    210
    NZ
    2003 Prius
    If you don’t have water flowing with the test in this video, you must fix that before any further tests!
  6. CommanderVitaly
    Philadelphia
    2002 Prius
    Thanks for the quick reply we already tried everything mentioned, we checked all the fuses, we checked all the cells and replaced the bad ones there was only like 2 bad ones. 12v Battery is brand new and the voltage is good, visual inspection for all 3 ecu was good and doesn’t look like the one under the passenger floor was ever wet. Inverter pump I’m thinking is good but I don’t think I can see any turbulence right now because the car doesn’t start at all right now. I haven’t been able to check for hv codes tho. I will try the Prius app. As for the mini-Vci, say that it won’t communicate, where do I look next? Where the 12v battery is there is that one wire that comes from the positive battery terminal and it looks like the previous owner taped it up, I’ll try to take a picture when I’m near the car. What does that wire do and do you think it can cause the issue? Also worth mentioning, when the car would only start 50% of the time before I would lightly tap with a hammer on the hv battery right on top where the orange plug is and it would let the car start again.
  7. CommanderVitaly
    Philadelphia
    2002 Prius
    Bump
    Still didn’t figure it out
  8. CommanderVitaly
    Philadelphia
    2002 Prius
  9. CommanderVitaly
    Philadelphia
    2002 Prius
  10. ChapmanF
    19,055
    Sorry, I must not have seen this at the time, and it may have sent you in the wrong direction.
    The ECU that's inside the battery case is the battery ECU. The HV ECU in a Gen 1 is beneath the carpet under the front passenger's feet.
    If P1636 is still the trouble code you've got, there is still electrical troubleshooting you need to do between this ECU and the ECM (which is behind the glove box). Progress may depend on solving that problem.
