Gen 1 2003 Prius-New 12V being Drain-3 Codes Present
Discussion in 'Generation 1 Prius Discussion' started by Mr.Reaper, Feb 4, 2018.
  1. Mr.Reaper
    Mr.Reaper New Member
    Fresno
    2003 Prius
    Gen 1, Toyota Prius, 2003, 96k miles: Initially the issues appeared when the car was being driven in the highway. There was a sudden noise and the car began slowing down with a message displaying saying to pull over. The car speed was reduced to 1 mph or less while it felt forceful. After getting the car towed, the 12v battery was replaced (self Install kit) as it had been drained by hazard blinkers and unable to hold a charge any longer. 12v battery was a success, unfortunately the new 12v battery is being consistently drained. After acquiring a Mini VCI cable and complicated shenanigans to make it work with win10 x64. I was able to acquire the following 3 codes from 3 different Categories:
    Hybrid Control Live
    P3000-battery Control System
    HV baterry Live
    P3009-Leak Detected
    ABS/VSS/TRAC Live
    C1259-hv System regenerative malfunction
    Further the following icons are present in the dashboard and/or display:
    Red Triangle !
    Warning: Red vehicle
    I would appreciate some suggestions/help since my research/lurking online did not yield any results onto how to proceed to narrow down the problem. Further i'd prefer the toyota dealer as a last suggestion since I am a college student with limited funds and from research online seemed to have eye gouging prices.
    Thank you again for your help.
  2. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    The code to focus on is the P3009-HV Isolation Leak Detected code. The other two codes are just echo codes that acknowledge they have seen the HV Battery ECU has a problem and to explain why they (the HV Control ECU and the ABS/VCS/TRAC ECU) have modified (if necessary) their behavior.
    Do you have a copy of the Repair Manual? As tracking down a HV Isolation leak is reasonably involved. Possible areas are HV Battery, main cable (frame wire) and connectors, Transaxle, Inverter and A/C motor.
    Others with more info will chime in soon, I hope.
    mroberds likes this.
  3. Mr.Reaper
    Fresno
    2003 Prius
    Hello
    No I do not have a copy of the repair manual although I could always acquire one from eBay if necessary.
  4. Mr.Reaper
    Fresno
    2003 Prius
    Also thanks to the information given dolj I did some research and found this youtube video regarding possible leak trouble shooting and narrowing down of the problem.
    Ill give this a go
  5. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Nice video find. My gen1 has just come up with this code P3009 so I've run this test. It possibly confirms that my battery has the leak. The car has been sitting for a couple of months, only starting it every couple of weeks, and we've had very rainy weather. I'm wondering if its moisture related so I'll find out when I start digging into the battery enclosure.
  6. mroberds
    mroberds Member
    143
    59
    2001 Prius
    I went through the P3009 diagnosis myself just over a year ago. The whole thread is here: Chasing info code 123 *without* P3000? Or do I need a better scan tool? | PriusChat
    The tl;dr is that I did all the factory service manual procedure, including megging out the cables, inverter, and transaxle. I ended up disassembling the bus bar modules from the traction pack, cleaning the bus bars and nuts with a wire brush and vinegar, rinsing them in clear water, cleaning electrolyte spoo from the ends of the battery modules and inside the traction pack, and putting it all back together. So far, the code hasn't returned.
    Your mileage may vary. :)
