Gen 1 battery computer assay replacement
Discussion in 'Generation 1 Prius Discussion' started by RathlinPhil, Jul 3, 2022.
  1. RathlinPhil
    RathlinPhil Junior Member
    Rathlin Island, Ireland
    2001 Prius
    I
    My gen 1 was reading 0 volts on three cells. I have the battery out and all cells are fine . It turns out that three pins are corroded and snapped in the multipinplug to the computer. Can I just replace the computer assay or is it coded to the vehicle? Thanks Phil.
  2. ammdb
    ammdb Active Member
    288
    119
    Indianapolis
    You can find a Gen1 battery ECU on eBay and swap it with the bad one in your car no problem. Might be worth finding out why the pins broke in the first place, it's likely the wiring harness is also corroded.
    https://www.ebay.com/p/1753530318
  3. RathlinPhil
    2001 Prius
    I
    Thanks, yeah the pins were badly corroded. That's great if it's a straight swap of the pc and harness. There's a couple of second hand gen1 batteries on eBay, just didn't want to jump the gun incase the computers weren't interchangeable. Thanks.
  4. ammdb
    ammdb Active Member
    288
    119
    Indianapolis
    For the money, if still available, a new Toyota battery pack is the way to go. It comes with new cables and wiring harness, but ECU, relay module, temp sensor harness, and a few other items need to be swapped over from the old battery before it's returned for the core deposit.
