Gen 1 Battery Rehydrating Experiment Results
Discussion in 'Generation 1 Prius Discussion' started by jeffkay, Mar 23, 2010.
  1. jeffkay
    jeffkay Junior Member
    burbank, ca
    2001 Prius
    I
    My car was totaled and still no codes shortly after my post above. Sealing is important. I never thought to weigh them!
    I think I have 3 good cells around (never opened). Dont need em so anyone make me an offer. My email is jeffreykloth (at) gmail.com
    bwilson4web likes this.
  2. bwilson4web
    16,527
    I'm sorry to hear about the loss of your car. However, it is consistent with our greatest risk, accidents.
  3. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    I've been in contact with Jeff. The 30ml is a typo. He added 3ml per cell.
    David White and strawbrad like this.
  4. codycowgill
    codycowgill Junior Member
    Rexburg, ID
    How often does the battery need to be re-hydrated after the initial procedure is done I wonder? I am going to perform this on my car.
  5. codycowgill
    Rexburg, ID
    Didn't the OP confirm it worked already or am I missing something? I am doing a grid charger reconditioning as well.
  6. Ancel Bhagwandeen
    Ancel Bhagwandeen Junior Member
    47
    40
    Caribbean
    Hi All, Interesting thread. I am organizing funding to develop module level battery regeneration in combination with cell level re hydration. I am considering plastic (nylon) screws dipped in JB Weld epoxy as the sealant for the NiMH module rework. I am an M.I.T> EE with a commercially developed 12KW lead acid desulfator that has 6S and 8S NiMH profiles built in , tested at University MSc level.
    I see 3mL or so water re hydration is suggested. I don't see why a bit more won't be beneficial in terms of venting longevity. Hot water is a good idea as it enhances KoH crystals back into solution. I have had success using sonic cavitation with lead sulphate crystals to enhance their destruction. I did this version of the desulphator for bloke, down under...
    I hope to achieve the same to accelerate the reconstitution of KOH solution via cavitation agitation.
    This is the new theory of cavitation in electrochemistry
    Electro-Sonication - Ultrasonic Electrodes
  7. bwilson4web
    16,527
    Good luck but my experience:
    1. Mechanical sealing fails - the Toyota patent cites plastic welding and I continue to believe this is the only practical approach.
    2. Sealing terminal seals is a hard problem - the loss of hydrogen via the terminal seals remains a hard problem that stopped me. In effect, the "O" ring around the terminal leaks the small amount of electrolyzed gas over time. There is no significant loss of KOH but the electrolyzed, water gas of hydrogen and possibly oxygen.
    My last thoughts were to drill out the safety vent and put a 'nipple' that lowers the peak pressure and retains/recombines the electrolyzed gasses. This can also provide a valve for water reinfection. Not trivial, it provides an 'after market' solution for rehydration and reduced gas loss.
  8. Ancel Bhagwandeen
    47
    40
    Caribbean
    So far sealing with a 4-40 steel screw results in at least 1 leak per blade. Resolved with plumbers teflon threadseal on the screw.
    My first trial didn't yield much (5%) AH improvement using a 10% NaOH electolyte (7ml) .
    Will give the cell another cycle later.
    Running another trial with just 10ml water and unsealed cells. That will allow excess water to evap. and enhance the dissolution of the KOH crystals better.
