Gen 1 Daytime running lights
Discussion in 'Generation 1 Prius Discussion' started by ibiwisi, Feb 8, 2012.
  1. ibiwisi
    ibiwisi Flathead Lover
    16
    Ohio
    2003 Prius
    :confused: How do I defeat the daytime running lights on a 2003 Prius and still have the headlights turn on and off with the switch on the turnsignal lever the same as my new Camry. The daytime brightness is 90% as bright as regular low beams and I don't feel I need that electrical draw when I don't need headlights.
  2. NinnJinn
    NinnJinn Member
    276
    Indiana
    I just asked this very question last night.. except my ordeal is, I keep forgetting to turn my lights on for night driving. only got one reply which was: "not that I know of. You'll get used to having to turn your lights on. There is a dashboard indicator for when they're on, and I quickly made a habit of it being on whenever it was dark or I needed wipers."
    But I agree with you 100% if it isn't a law, why waste juice?
  3. Catalinux
    Catalinux Junior Member
    43
    Romania
    2013 Prius Plug-in
    Just take out the DayTimeRunning Light Relay (I'll attach a picture for you to see where is the location.
      File size:
      71.2 KB
      1,388
  4. Irrenarzt
    Irrenarzt Junior Member
    35
    Half a mile from Tucson
    2003 Prius
    I
    Do you remove the dash to access this relay?
  5. Catalinux
    43
    Romania
    2013 Prius Plug-in
    Unfortunatley , yes, but it can be done more difficult by reaching under the dash at the driver side (just take out the connector)
  6. Irrenarzt
    35
    2003 Prius
    I
    Sounds like a bitch. Bummer.
  7. ChapmanF
    18,951
    You might want to look at the Art's Automotive page on replacing the key transponder ECU. The first black box he came to, which annoyed him because it wasn't the right one and had to be moved out of the way, might be roughly where the right one is for you. Then again it might not (the illustrations can be a little vague).
    -Chap
