Gen 1 has its own built in charger!!
Discussion in 'Generation 1 Prius Discussion' started by hybridbatt, Jan 31, 2015.
  1. Stokie
    Stokie Junior Member
    New Zealand
    1998 Prius
    I
    Yes indeed, if I was going to use them directly or in parallel with the traction battery, but I was thinking about the possibility of up-scaling the 12v parallel-wired lead batteries to the high voltage required, using the built in charger circuitry. Although probably not enough wattage available due to the charger's output limitations...
  2. Sharon Ruth
    Sharon Ruth New Member
    2003 Prius
    Hello,
    This is my first post. I have a 2003 Prius and the turtle light came on. I managed to limp home and put the car in my carport. However, after letting the car set for awhile, whenever I started the car and put it in gear, turtle light came back on and the car wouldn't move. I know it says in the manual something about 'not having full acceleration' . I didn't have ANY acceleration. When this happened, my car had been outside in Texas sun for about an hour. What do I do?
  3. Sharon Ruth
    2003 Prius
    I forgot to say that I have 167K miles on it - bought it when it had 15K and LOVE it! I hope to drive it another 167K!
  4. S Keith
    S Keith Senior Member
    799
    327
    AZ
    2003 Prius
    Given the mileage, it's likely the battery. It's probably time to put it out to pasture; however, you can't be certain without reading the codes.
    Code reading options in my signature.
    Good luck,
    Steve
