Gen 1 HV BATTERY REBUILD WITH 2G CELLS
Discussion in 'Generation 1 Prius Discussion' started by UKCLASSICPRIUS, May 15, 2010.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    My diagnosis: very talented Prius technician, with an inferiority complex.
  2. bwilson4web
    16,012
    If I understand his posting correctly:
    • vehicle starts, goes into READY, engine runs and charges - MG1 sounds good, engine sounds good,
    • vehicle runs forward without errors - MG1/MG2 sound OK and the parking paw disconnected. Normally a fraction of the power, ~28%, should take the MG2 path. We can't really tell but if there are no errors raised so it sounds OK.
    • vehicle fails when shifted into "reverse" - so what is different? MG2 signals and power are the same, just different timing. There is no internal mechanical gear. The HV ECU handles the timing in response to the operator control. I'm not ruling out another failure mechanism but it sounds like this is the first time "R" setting is being attempted with the shifter.
  3. bwilson4web
    16,012
    Owch! It has been a long, long time since I can remember feeling "inferior" . . . although some forms of pornography come close.
    In all seriousness, folks here make a name by showing what they've got. Tearing down others, who has time? Who cares? It hurts the reputation of the critic, especially when they don't bring anything else to the game.
    The trick is to ask folks to 'demonstrate' their talent, bring on their "A game" and show what they know or can figure out and don't sweat the small stuff.
  4. jk450
    jk450 New Member
    55
    If you think folks have an inferiority complex when they make a sincere effort to help someone with a broken car get it running as quickly and cheaply as possible, and make that effort anonymously, then please, sign me up twice.
  5. jk450
    jk450 New Member
    55
    That's what I understand, as well.
    Yes, but there are errors, and codes to define them.
    In reverse, there is no engine torque to propel the vehicle.
    A well-written fail safe strategy will protect the driver and the vehicle first, and try to get the driver home as a second priority. And that's what is happening here. Since engine torque is available, it can be used to propel the vehicle forward after the HV ECU "sees" that for some reason it shouldn't use MG2. In reverse, however, it briefly applies torque, and then some fail-safe threshold is triggered. However, we don't know if it's MG2, the inverter, the battery, or something else at fault.
    You are trying to diagnose the vehicle from its behavior. However, the "behavior" of a Gen 1 Prius with codes is often no more than a fail-safe mode that has been triggered by the root cause of the problem, to protect the vehicle and its occupants.
    If a shift selector circuit problem was the issue, I'd expect the vehicle to not go into reverse at all, and to set a code. At this stage, all indications point in another direction.
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    ^^ Thanks for the informative post without the attitude. *So* much easier to digest and learn from.
  7. jk450
    jk450 New Member
    55
    You haven't been paying attention. There is ample reason for, as you say, "attitude".
    While forum member bwilson4web posts regularly on this forum, many of his posts are, unfortunately, riddled with errors. This is not, of course, a cardinal sin; we are all here to learn and to try to help.
    Unfortunately, he often throws quite the fit when anyone posts technical information that contradicts his theories, and works to discredit or drown out such information, even if such efforts could inhibit the successful diagnosis of a broken car. When that hasn't worked, he has resorted to name-calling and other personal attacks. In that sense, he is unique among all forum members. To be blunt, he is a very angry man. You can see it for yourself in this thread; after I had pointed out errors in his posts and made an effort to put the diagnosis back on track, he responded
    Not much to laugh about, really. Indeed, it is not difficult to find threads in which folks have spent weeks trying to diagnose their vehicles based on his theories, eventually giving up and wandering away. I don't think that's funny, and I hope you don't, either.
    To be frank, the advice that bwilson4web gives is often so far off the mark that the most helpful thing one can do is try to steer the OP away from the largest howlers. There is simply not enough time to fix it all. So when I read responses such as
    I am well aware that it is BS, rather than a genuine sentiment. You, unfortunately, were not, and that's why Mr. Wilson has played you like a piano. In all sincerity, I wish you better luck next time.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    Thanks for the concern. Let me tell you, it has been agony on my poor toes.
    Now, BACK TO TOPIC.
  9. jk450
    jk450 New Member
    55
    With all due respect, you initiated the diversion. What do you think is wrong with the OP's vehicle?
  10. UKCLASSICPRIUS
    127
    UK LONDON
    Guys I would hate to say it, BUT please! Lets be professional about this
    We are here to help Each other...
    (I can understand All of your different frustrations Individually! & I try not to get involved, BUT I can see you ALL have a Good hearts! right through yourselvs...)
    Let me try & work on the Info codes!
    Speak to you all in a bit, I am sure you know How much I appriciate all your posts...
    & thank you all, for taking your own personnal time Out to do Headscratching equations for my Dead prius.... I do deep down feel I owe you guys one..
    Lets all Put our guns away, Before someone gets hurt! (Pretty Please)
  11. jk450
    jk450 New Member
    55
    When you rebuilt your HV battery, did you disconnect the 12V battery?
  12. UKCLASSICPRIUS
    127
    UK LONDON
    YES the 12v AUX battery was disconnected when removing the OLD HV battery, & was only connected back up WHEN the replacment cells were fitted...
    I read that there is an "ACTIVE TEST" that is used to initialize the Battery Ecu? (I read this in the prius DI manual) Could you just explain what they mean by that? Not that its directly aimed at me But still for the knowledge...
    ALSO, I have NOT put back on the Cover for the HV battery, & a few of the ventilation Pipes, (to make it easy for testing) Do you recon there are any safety devices ACTIVE, that are the root cause of my results?
  13. jk450
    jk450 New Member
    55
    Great, then you'll only be seeing current codes if you are able to access them.
    You would be able to skip that step without a problem when swapping a Gen 1 battery ECU.
    For the codes you are reporting, no.
  14. bwilson4web
    16,012
    Ok, let's get back to work. I've turned up the squelch.
    FUSES
    It took these rather grainy photos Friday morning of the two engine compartment fuse boxes:
    The empty slots appear to be places for spares. I do have a few spare fuses in the boxes. Otherwise the fuses and relays look ordinary.
    I'll start a follow-up post with hopefully the current symptoms.
  15. bwilson4web
    16,012
    BACKGROUND
    • P3100 - HV ECU malfunction
      • Check and reseat connectors - again there are a long list of subcodes but without a Techstream, they are not otherwise available.
    • P3125 - Converter & Inverter Assembly Malfunction
      • Huge list of subcodes, pp DI-271-306 this is where the Toyota Techstream provides a roadmap. This is where getting the codes from a Toyota service center pays off. Start with checking the connectors.
    • ABS light - this controller will flash the error codes if you use the OBD connector jumper technique described in "AE Pig-tail and code flasher"
    • vehicle runs forward without errors - MG1/MG2 sound OK and the parking paw disconnected. Normally a fraction of the power, ~28%, should take the MG2 path. We can't really tell but if there are no errors raised, it sounds OK.
    The HV ECU operates the inverter. So it makes sense to look at the inverter HV ECU signals first and those associated with "reverse." Let's look at a list of all HV ECU signals and see which ones we can rule out and those of interest.
    The H10 connector connects to the motor generators, MG1 and MG2. Since MG1 appears to be OK but MG2 fails on reverse, lets keep these as 'signals of interest:'
    Column 1 Column 2 Column 3
    0 signal line color
    1 msng 20 green
    2 msn 13 red
    3 mcs 14 pink
    4 mcsg 21 blue
    5 mrf 19 black
    6 mrfg 18 white
    7 mmtg 9 red-white
    8 mmt 2 gray
    These are likely sensor from MG2, possibly the resolver.
    Now H11 carries the signals between the inverter and HV ECU:
    0 signal line color
    1 msiv 21 green
    2 msdn 13 yellow
    3 mit 11 blue
    4 mwu 6 green
    5 muu 4 red
    6 mvu 5 white
    7 mivg 26 black
    8 miva 16 black
    9 mivb 7 white
    10 miwb 17 green
    11 vb 20 yellow
    12 miwa 25 red
    13 giva 19 black
    14 givb 8 white
    15 giwb 18 green
    16 giwa 28 red
    17 gsdn 12 yellow
    18 git 23 blue
    19 gwu 3 green
    20 gvu 2 white
    21 guu 1 red
    22 givg 1 black
    23 mpiv 14 black
    24 gsiv 15 green
    25 gpiv 24 black
    These are the signals common to both codes.
    Now the last signal of interest are the shifter on H13:
    0 signal pin color
    1 R(everse) 14 Red-Blue
    2 vsft 12 white
    3 sft 11 black
    4 gsft 21 red
    Of interest because reverse is associated with the latest error.
    So now comes the challenge, working off the list. Where would you like to start?
  16. UKCLASSICPRIUS
    127
    UK LONDON
    Took apart the HV Control ecu, & re -seated its connections.... (so they are all visible) No nasty stuff all Look clean as a whistle... *& just for the Record, Its on the Passenger side of a UK model RHD prius...
    & Afraid to say it, BUT took OFF the Invertor / Converter... & I forgot to tell you this part, BUT the invertor convertor looks like & was told its a brand new Part... & is shiny as hell... (will take pics, & have many to upload) I could litrally eat my dinner offit!
    The history of the car WAS that it came from a toyota dealer, & its got 50 miles over 100k, & is a one owner car... So I think it ran out of warranty by a few miles, & the owner OR toyota never bother with it...
    The interior of the car looks like brand new, the exterior is not too bad either.... & came with brand new tyres all around, With everything packed away nicely in the golve box, & original toyota keyring etc...
    So it HAS been Previously taken care off....
    Thats a Nice list you have thier Sir Bob Wilson....
    I am still in the process of sorting out someone to read the codes out properly, With the Info codes...
    Hopefully I will have the invertor back in ASAP, It was installed properly with No loose wires or connections...
  17. bwilson4web
    16,012
    Reseating the connectors seldom works but it is relatively 'cheap' and yet works often enough. Sounds like they are in good shape. Also, thanks about the HV ECU location. This suggests the engine and power steering ECUs may also be located behind the glove box.
    Did you remove the coolant lines? The reason is replacing the coolant is tricky to get the air bleed out of the lines. In my case, I've taken the inverter 'out' without opening the coolant lines. I have replaced my coolant before including bleeding the lines.
    Let's see if we can keep it rolling a little longer. <grins>
    There is a UK member of the "Prius Technical Stuff" group, Clive, who has an NHW11 and others who have posted from time to time. There is also an European Prius group whose activity varies. If you introduce yourself, maybe one of them might volunteer to come 'take a look' at her.
    Tell me more about the 'inspection' deadline ... the end of this month. What is the risk if the car is not through inspection by the end of the month?
    The reason I ask is it has been dreadfully hot, 35-38 C with a lot of humidity. I've been taking the dogs out for their walks before sunrise and it is still equitorial.
  18. UKCLASSICPRIUS
    127
    UK LONDON
    Bob I am working on this specific Post as we speak............
  19. UKCLASSICPRIUS
    127
    UK LONDON
    Hi Bob, The inverter is installed back in place, & pumped back the coolant that I originally drained out...
    I had disconnected all the coolant lines to remove it fully... I am sure I got air in the system Now, I have bled the nipples in front of the inverter itself, Was hoping it would settle once I had it running... but the level should go lower & it has not yet, So there is air still in the system..
    The prius stared backup the same way...
    Are these European prius users on this forum or another? I would LOVE for someone to come & give my car a once over, I would give them more then a Beer Belly, LOL!!
    I thought the TAX was running out the month that just went, BUT I have another month, its running out at the end of this month... (without road tax your cars not allowed to be on the road, & I have not got a Private drive on the front garden...)
    NOW I have the inverter back in, I want to get the Sub codes read ASAP!
    Studying the list you posted Bob, of those plugs....
    Cheers...
  20. UKCLASSICPRIUS
    127
    UK LONDON
    Another thing to note, is that the rear wheels seem to be quite jerky when I try to Manouver forwards etc.. Something to do with regenarative braking? OR brake pads disks etc???
