Gen 1 ICE will not start
Discussion in 'Generation 1 Prius Discussion' started by Nelsonprius, Jan 16, 2022.
  1. Nelsonprius
    Nelsonprius Junior Member
    72
    Nelson, BC Canada
    2001 Prius
    I
    Was driving fine then cold snap came,it would not start, thawed and still won't start.
    Ice is turning over 2 seconds but doesn't catch. Red Triangle, engine light, ABS light on and steering froze stiff
    Carista & ELM327 will not connect to ECU for Dr Prius & Torque. 12v charged.
    No visible blown fuses but I assume burnt electrical because just before it died the dash & headlights would go dim and off then on dim then off.
    Any ideas before I scrap? Who Needs an OEM Cat?
  2. Rmay635703
    Rmay635703 Senior Member
    2,701
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Air
    Fuel
    Or
    Spark?
    I would check all 3, could be something as stupid as a pump
    no spark is easy to test as well
  3. AlexY
    AlexY Member
    163
    45
    UK
    99% throttle body need cleaning.
  4. jamesprius
    jamesprius Member
    142
    17
    San Jose, California
    2001 Prius
    I
    could be interested in the cat, if you decide not to fix the car..
  5. ammdb
    ammdb Active Member
    287
    119
    Indianapolis
    Sounds like a weak 12V battery, have you tried jumping it from another car?
  6. AlexY
    AlexY Member
    163
    45
    UK
    He said
    Also if engine is cranked, system is switched in to 14V inverter.
    Need codes.
  7. Rmay635703
    2,701
    1,729
    2013 Chevy Volt
    Too bad you are in Canadia
    I would pick up the whole hill locally (always wanted a tax excepted 1st Gen)
  8. Nelsonprius
    72
    Nelson, BC Canada
    2001 Prius
    I
    Has air fuel and spark and 12.4V.
    HV charged up, immediately discharges with ignition on start, I assume a power motor short or relay short
    codes p3000 and p3009 c1259 c1521, power steering was erratic as well.
    I don't want to put big money into it, guess I'll part it out unless you can think of a simple fix
  9. AlexY
    AlexY Member
    163
    45
    UK
    p3009 is leaking electrolyte from traction battery.
    Other codes are result of this one, most likely...
    Would start with traction battery refurb but this is not simple fix for everyone.
    Nelsonprius likes this.
  10. Nelsonprius
    72
    Nelson, BC Canada
    2001 Prius
    I
    Will new gen 2 busbar replacements fit in Gen 1, just fewer pcs ?
  11. AlexY
    AlexY Member
    163
    45
    UK
    You mean copper links between modules? Yes. I bough copper pipe, cut it along, flatten, drilled holes, works fine.
  12. Nelsonprius
    72
    Nelson, BC Canada
    2001 Prius
    I
    HV battery had 13 bad modules , replaced, works better than ever, just don't know what caused the sudden battery fail.
    Car is for sale in BC Canada $3000 US or $3700 Cdn, near top of Idaho Handle
    , I needed a replacement and can't keep 3 cars where I am
  13. AlexY
    AlexY Member
    163
    45
    UK
    Probably age, most likely it was so weak that even cranking ICE was too much for it.
