Gen 1 Plug-in Kill Switch
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by prEEus4848, May 26, 2022.
Tags:
  1. prEEus4848
    prEEus4848 New Member
    Portland
    Hi all,
    Has anyone successfully put a kill switch on a gen 1 plug-in? I've got a 2012 plug-in that I need to put a kill switch on (moving to a *very* high theft area) and I've read through a lot of threads, but none specifically for a plug-in model.
    This thread suggests using starter kill in conjunction with an alarm, which seems like a good idea, though I couldn't quite follow all the technical details.
    This thread suggests isolating the brake pedal switch with a killswitch, so the car couldn't go into ready until the killswitch is closed.
    Neither of these were for a plug-in model, and I don't know that either of these were actually implemented or successful.
    Anyone have any success stories or suggestions? Thanks!
  2. QuantumFireball
    QuantumFireball Active Member
    419
    267
    Ireland
    Does it really make much sense for a modern car with an immobiliser? If they really want it they're either going to break into your home and steal the keys, or just put it on a flatbed.
    49,399
    you can use the same technique from any gen 3 if you can find one, they are all the same.
