Gen 1 Prius MFD Part Numbers
Discussion in 'Generation 1 Prius Discussion' started by RW5207, Dec 14, 2015.
  1. RW5207
    RW5207 Junior Member
    32
    Dallas, TX
    2002 Prius
    I
    Are there multiple part numbers for the MFD on my 2002 Prius? Is there a "navigation" display and a "low-res" display? If so, does anyone know what those part numbers are and if I can swap out my non-navigation display for one that had navigation?
    Thanks...Russ
  2. ChapmanF
    17,326
    As far as I know, it's the same MFD, you just add the nav unit (mounts under the passenger seat) and the antenna (goes up near the instrument cluster) and they plug right in if the wiring was already included in the harness, otherwise you acquire some wire harnesses and do some splicing to make it work.
    Check for posts on the subject by one mlibanio ... he's the authority. It seemed like you can probably get the system up and running for about, oh, eight or ten times the price of a nice Garmin....
    -Chap
  3. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    728
    Boulder Hybids, Boulder, CO
    I wouldn't even think about trying to fix or convert a Gen1 to have factory Nav. That system blows! Buy a Garmin, TomTom, or just use your smartphone.
    bwilson4web likes this.
