Gen 1 Prius starts second try
Discussion in 'Generation 1 Prius Discussion' started by jimamiller, Apr 6, 2019.
  1. jimamiller
    jimamiller Junior Member
    new jersey
    2002 Prius
    I just ran into a new problem when I replaced my battery last week with a greentec refurb main battery. I still have the triangle saying the battery pack is bad. I have no code showing on my reader.. Before the battery replacement I had p3006 and p3028. The car will not start when I turn the key. The car always starts (so far) when I turn the key a second time. Everything else seems to be fine. Once started the car runs as if it has a new battery. I am guessing the reset that was done when the new battery was installed did not work like it should have. I don't know how to do a system reset. I work as an electronic technician so I am familiar with the business end of a VOM. Do you have any advice?
    Brian in Tucson likes this.
  2. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    The system resets when you disconnect the aux battery, the one in the trunk. The best diagnostic system is to buy a mini VCI and a pirated copy of Techstream. Install in an old laptop, mine is an old XP Dell. Are you still getting codes? Any check engine light or other warning lights? A VOM is of minimum utility as are generic OBD scanners.
    Welcome to the forum.
  3. jimamiller
    new jersey
    2002 Prius
    I thought I had the problem solved by charging externally the auxiliary battery. It worked for awhile but the issue is back. I drive the car only on weekends as I have another vehicle for work. I bought a remy battery in May of last year and it looks like that is the issue again. Thanks for the help.
    52,401
    put a maintainer on it
