Gen 2 12v battery went from 12.8v down to 5.8v overnight. Just had it load tested yesterday.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Longinus876, May 27, 2023.
  1. bisco
    51,944
    I wish I could remember all that for the future
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,155
    6,313
    Texas Hill Country
    If the car is running now after replacing the 12v you are probably dealing with a marginal hybrid battery now. It is possible your brake booster is failing as well or it could be a bad wheel speed (abs) sensor. These are very common issues on an 18 year old Prius.
    I would drive it on a freeway for 15 - 30 minutes while watching the dashboard charge indicator for a 80% or better charge. In some cases the hv battery will recover.
    In the end you are likely to need a "refurbished" hybrid battery (used) or new set of modules installed in your hv battery assembly.
    Most users of this forum are advanced diy who will try any hybrid repair. They have done it before or know enough to chance it. Ask yourself if you want to tear down a battery or braking control system.
    Sometimes it might be worth driving 50 miles to get a good price at an independent shop with hybrid experience. There are independents who do nothing but Prius batteries and work, usually for half the dealers price. Many get new cells installed for $2300 or less. Others go refurb for $1600 or less. The refurb guys guarantee their work but failures in less than a year are common.
    Techstream has a learning curve so I am not sure I would invest $300 or more if you are not fairly fluent with the hybrid systems and wiring in the car. The guys here are not too good at walking someone through the basics of Techstream.
    Given you are likely dealing with the hybrid battery now, the free Dr Prius app and a $35 bluetooth adapter is probably all you need to see individual hv battery module readings.
    This bluetooth reader will work with an Iphone or any Android smartphone or tablet. The Dr Prius, Car Scanner or Torque apps are free to use for monitoring.
  3. Longinus876
    Longinus876 Member
    105
    Long Island
    My cell phone screen is smashed so I'd rather use my wife's Kindle Fire if it's possible. Much bigger screen. I don't know if it would link up to an OBD though. It has Bluetooth but it runs on a different system. Not android or iOS. Would you have any info on that? Also, someone said to use the flash code first because it's there and it's handy.
  4. rjparker
    10,155
    6,313
    Texas Hill Country
    No it won't work. So you are using the smashed phone here or are on a Pc? First thing I would do is fix or trade the phone.
    Independent hybrid battery sellers near you might scan it for free.
    Android: if your phone is Android use this one or similar with 32gb. $59
    However if you have an Iphone now I would get a used Ipad with at least 32gb.
    #64 rjparker, Jun 14, 2023
  5. Longinus876
    Longinus876 Member
    105
    Long Island
    That link only shows the phone. Which phone is that from Amazon?
  6. Longinus876
    Longinus876 Member
    105
    Long Island
    What's the Android one?
  7. rjparker
    10,155
    6,313
    Texas Hill Country
    It is a Ipad, not a phone. A tablet with wifi and bluetooth.
    Keep in mind a scanner will only help to prove the hv battery is bad, it or Techstream won't fix anything. With the code you have and age of the hv battery its 95% you need a replacement.
  8. Longinus876
    Longinus876 Member
    105
    Long Island
    It sounds like you're suggesting I get a new HV battery.
  9. Longinus876
    Longinus876 Member
    105
    Long Island
    Got everything working, thanks for your help. Yes, I didn't think the scanner would fix anything. I have a brake warning light on now and i assume it's not related. Car has 110k on it and original brakes. Thanks again for all the help. I shall return...I'm sure. Happy Father's Day.
  10. swing
    swing Junior Member
    84
    17
    CT
    well dont keep us in suspense, lol!! - what was the eventual solution to the parasitic drain issue?!!
    Jon in CT :)
  11. rjparker
    10,155
    6,313
    Texas Hill Country
    It appears the underlying problem after he bought a new 12v battery was the orange disconnect was not properly closed.
    June 14th
  12. swing
    swing Junior Member
    84
    17
    CT
    Well, you definitely have to push it down as the final step to make contact!...
    .....just scratchin my head as to why that caused the 12v battery to drain so rapidly? - any idea?
  13. rjparker
    10,155
    6,313
    Texas Hill Country
    I am guessing his measurement technique was poor such as leaving the hatch open, wrong scale or not waiting for the computers to sleep. Remembering he had a bad 12v in the first place.
    #73 rjparker, Oct 20, 2023
    swing likes this.
