Gen 2 (2004) GPS
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by steve0826, Sep 22, 2022.
  1. steve0826
    steve0826 Junior Member
    30
    Bellevue, WA
    Quick question:
    My 2004 Gen 2 Prius has GPS problem. The further away I drive from home, the more inaccurate it goes.
    Does replacing the MFD fixed the problem?
    Asking because I can buy one MFD from wreck yard for $150.
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,436
    Pacific Northwest, USA
    Probably not worth it if it doesn't work, which seems likely... And with GPS software coming up on 20 years old it's going to screw you up more than it helps you because lots of roads and intersections have been changed since way back when and any smart phone is not only going to give you way more accurate GPS updates, but real time re-routing that will give you short-cuts around traffic, car accidents, construction, etc.
  3. pasadena_commut
    pasadena_commut Senior Member
    3,068
    956
    Southern California
    Cell phone + software + cell phone holder?
    You probably already own most or all of that and you won't have to take the dash apart and risk snapping off any of the old brittle plastic clips which hold it together.
    PriusCamper likes this.
  4. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    If you decide to go ahead make sure you get the correct part # MFD.
    MFD 86110-47230 Compatibility | PriusChat
