Gen 2 2007 AC issue!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ohem, May 18, 2026.
  1. Ohem
    Ohem Junior Member
    Sweden
    Hi!
    I've been having a problem with my AC, and I can't pinpoint when it occurred, as I haven't always needed it on at most times. Since about somewhere in March the AC didn't quite blow cold, it wasn't an issue as the ambient temp wasn't that hot to begin with and I didn't think much of it. But now it's warmer and now it's an issue.
    I refilled the system with an AC in a can, and it hasn't made a difference. I can hear the compressor go "brnnnnnn" whenever it's turned on, and the AC diagnostic system gives me "00" so no issues there, but I don't know if it's reliable. But I can't see any "snow" in the glass on the "High" side, can't tell if the mixing doors move because of the sound of the blower motor. There's no smoke to see or smell a leak.
    I'm on disability, so any suggestions or tips that don't require a mechanic would be much appreciated.
  2. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    It's a variable pressure system so adding AC in a can to a specific pressure is likely to cause more harm than it solves. The DIY solution is a vacuum pump to evacuate the system and add exact weight of refrigerant and lubricant. Of course this will only work if you have an AC compressor that's working correctly. So all this would likely lead to paying an Auto AC shop that regularly works on Prius to have a look at it for a diagnosis.
    Have you changed the cabin air filter or run the system without the filter? Maybe there's a cause beyond the AC system?
    If you do have a bad compressor you can buy a used one from a wrecked Prius or a cheap aftermarket/rebuilt one online and install it yourself and figure out the weight of an empty can refrigerent and lubricant and subtract that number from a full can to inject the correct amounts.
  3. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    AC work requires tools that most people do not have, among them a set of manifold gauges and a vacuum pump. In addition the Prius AC is finicky about what is put into it, and adding the wrong stuff could really screw it up. So your choices are either to buy the tools and study up on the subject enough to learn to use them, or take it to a mechanic. There are mobile HVAC mechanics in the US, probably in Sweden too, that would save you the trip (if not the cost).
