Gen 2 A/C compressor issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Randy Smith, Jun 26, 2018.
  1. Randy Smith
    Randy Smith Junior Member
    Larchmont, NY
    Recently acquired a 2004 gen 2 with 220k on it. A/C hasn't worked in 2 years for sure. Recently attached gauges and found system at zero psi. Evacuated the system @30"Hg for 30 min suspecting a leak. Closed off the gauge valves and it held 30" for 1 hour. Maybe no leak ? While recharging with pure r143a, no additives, system got to 90psi both sides on approx 6 oz. Compressor cycles on for 5-6 seconds, makes a fairly loud buzzing sound, then off for 10 then back on about 4 more times but no drop in low pressure or increase in high pressure sides. A/C computer throwing 21 and 76 codes. Bad compressor vs bad expansion valve ?
    SFO and karmakid64 like this.
  2. karmakid64
    karmakid64 Junior Member
    New Jersey
    im not a mechanic but I have read in threads, when refilling, you need to add a special oil to the a/c system as well?
    SFO and Mendel Leisk like this.
  3. Mendel Leisk
    42,264
    Is it bad to run the compressor, even short time, without oil? This is something I always hand over to dealership, no clue myself. Anyway, here's some Repair Manual excerpt.
    • AC.pdf
      File size:
      3 MB
    #3 Mendel Leisk, Jun 27, 2018
    SFO likes this.
  4. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    You only add the special oil(ND11), if there has being a leak. But if no leaks, and want to recharge the system, compressor oil, isn't needed.
  5. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Totallebad running any kind of compressor system, without its oil.
  6. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    It might be your compressor is overworking. Have you checked the condenser, if excess heat is coming out from within that location?
    Can you just scanned the codes using a scantool, and post codes here? I know you have the 21&26. I don't get what they mean either.
    PS: I hope that noise isn't suggestive of a knocked compressor.
  7. Randy Smith
    Larchmont, NY
    Thanks, my thinking also but where did the r143a go ? Mystery. I have to find a scan tool and locate a gen 2 compressor and listen to it, I am a Prius newbie. I figure Winter isn't that far away !
  8. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Wao! Where did the r143 go? Then, you got a leak in the system, you got trace.
    The scantool would tell you what specific codes and faults you needed to limit your diagnosis.
  9. Randy Smith
    Larchmont, NY
    Anybody know what the A/C compressor windings resistance should be ? I am thinking my noise is a locked rotor in the compressor as I am getting a err 76 which refers to compressor rotation load . I have been looking to see if there is a circuit breaker which would explain the 5 seconds on then off cycling.
  10. Mendel Leisk
    42,264
    Might be this:
    upload_2018-7-6_5-52-32.png Starts on page AC-111 (actual page number 2692) in the attachment with my previous post.
    #10 Mendel Leisk, Jul 6, 2018
  11. Randy Smith
    Larchmont, NY
    IMG_1381.JPG IMG_1382.JPG Thanks for the info, it's been a while but It finally pulled the compressor and as all expected it was a total meltdown inside. See attached.
    And this is my question is all of this rubble through out the system ? I picked up a used compressor and tested it, (don't ask how) pondering next step.
    Raytheeagle and Mendel Leisk like this.
