Gen 2 ATF - Toyota UK say it never needs changing !
Discussion in 'Gen 2 Prius Technical Discussion' started by DelBoyTrotter, Jul 17, 2019.
  1. DelBoyTrotter
    DelBoyTrotter Junior Member
    22
    Ireland
    I’ve seen the tread come up so often about ATF ! Having been told completely different things by 7 different Toyota main dealers I decided to contact head office UK !
    Toyota Reply: According to our technical team, under normal conditions there is no interval for fluid replacement. However, it should be checked every 3 years. We hope this helps!
    52,822
    they are correct!:)
    but you are free to research the issue, and make your own educated decision
    can you enumerate all seven different positions? i'd be curious to know
    Raytheeagle likes this.
  3. Mendel Leisk
    42,323
    I would change it, no hesitation. Judging just from the color of drained fluid, the first drain does the most good, and it's hard to change it too soon. I'd suspect due to gears "breaking in", meshing. Subsequent drains look better, maybe less worthwhile.
    It's dead-easy to do. Hopefully you can acquire 4 quarts of Toyota ATF WS fluid over there without too much financial grief, I've heard some horror stories. Locally for me it's $9.14 (CDN) per liter.
    The attachment is the 2nd gen Repair Manual level check, they don't have a drain-and-fill instruction. It does identify the drain and fill bolts though, and specs refill qty. The simplest way to get it right is to refill with the car level, till it starts coming back out. Again, 4 quarts should do it.
    Toyota recommends to only use fluid from freshly opened bottles, don't store left overs for another change.
    Take a look beforehand, see what the second gen drain and fill bolts look like. I believe one is a regular, largish metric socket size, and the other requires a 10 mm allen-key style "socket", it's what's referred to as a "socket head cap screw".
    It's good to have:
    1. Torque wrench (29 foot/pound is fill bolt spec, drain bolt spec not mentioned, but the same should do)
    2. funnel with about 3 foot hose extension (hose OD no more than 5/8")
    3. A long handle breaker bar or ratchet wrench, with an extension or two (the bolts are kinda glued on)
    4. The proper sockets (have a look in advance)
    5. Replacement washers for the two bolts. Hopefully dealership can find, and for less than king's ransom.
    Also, obviously: ramps, or safety stands and floor jack.
    #3 Mendel Leisk, Jul 17, 2019
    Skibob likes this.
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    They said the same thing about the fluid in my 2005 Tacoma, then they changed their minds and changed it to 60,000. Probably after they started replacing transmissions under warranty. I say change it. Can only help, can’t hurt.
    srellim234 likes this.
  5. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    I would take almost any "lifetime" fluid assurance to mean, "Our goal is to sell you a new car or make a lot of money doing an expensive repair on your older vehicle." Almost any car manufacturer selling vehicles in America would tell you the motor oil never needs to be changed if they thought they could get away with it.
    ChrisFaehrtPrius and Skibob like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Seems pretty bimodal of a decision to me too;).
    But I’m not on that side of the pond(y).
  7. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    Lifetime filled is an illusion in my opinion.
    I have seen it with ZF transmissions where the car manufacturer claims lifetime filled but ZF tells you, please change the fluid every 80000km to keep everything in good working order.
    Car manufacturers make these claims, together with overall long service intervals, to satisfy fleet owners. Fleet owners tend to keep cars for max of 5 years so the car with the lowest maintenance cost over those 5 years has a better position. After 5 years they sell the car of and the manufacturer doesn't care if the transmission goes out after 5,5 years.
  8. DelBoyTrotter
    22
    Ireland
    3 dealers said no need to change (some hesitant) another said do it at 50,000 miles , another said 100,000 , 150,000 etc.. some nonsense..
    It’s clear as day everywhere Engine oil needs to be changed, this isn’t mentioned anywhere so I’ve Decided not to change it. Let’s yous know if there’s ever a problem. I’m at 117,000 miles now, If head office says no need , the chances are it’s nothing to worry about, I changed the ATF WS oil twice in my last Prius Gen 2.
    Kind Regards
  9. frodoz737
    frodoz737 Top Wrench
    4,798
    2,560
    33
    Toyota says DOT 3 brake fluid is lifetime in a Prius too. :ROFLMAO:
  10. ChrisFaehrtPrius
    ChrisFaehrtPrius Junior Member
    29
    Hamburg, Germany
    Just get a quote for an ATF change from your dealer, if they say it isn't necessary, tell them you want to do it anyway. It shouldn't be overly expensive. It is similar to a motor oil change but without the filter, so should be cheaper. The ATF is about $50 for a full refill.
    The car should be at operating temperature for the oil change and the fill plug should be opened before the drain plug. That way you'll get most of the crud out.
    DelBoyTrotter likes this.
  11. Mendel Leisk
    42,323
    The car should also be level when refilling, and fill till it starts coming back out.
  12. bisco
    52,822
    I've never done mine, but i don't keep them beyond battery warranty
    DelBoyTrotter and Raytheeagle like this.
  13. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Did the 08 get done when you transferred it to your daughter?
    She ever end up selling it and for a decent price?
  14. bisco
    52,822
    no, she sold it with 135k i think. no tranny fluid change. she finally accepted $4,500. seems to be a pretty hard sell around the land of suv's.
    a well heeled couple bought it for their teenage sons summer job.
    my neighbor still has my '04, no tranny fluid change. he only uses it for commuting, maybe a60 to 170k now.
  15. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    it seems that Toyota doesn't care if their dealers employ retards and scumbags. I hear nothing but horror stories about Toyota dealers lying, cheating, stealing and butchering customer's cars.
    what I will say is that when I changed the trans oil in my 2004 at 100k miles, the fluid was black, and there were flakes of metal on the drainplug magnet. my brother had the car at 160k, and when he changed the trans oil at that time, he said it was still red. therefore, I would definitely change the fluid at least every 100k miles. I can't prove it will help, but it surely can't hurt, and the dealers advice cannot be trusted even a little bit.
  16. DelBoyTrotter
    22
    Ireland
    Cool thanks for that
  17. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I never did our 2010 until 140 k miles and it was black:cool:.
    So when we bought the RX450h, I changed both trans fluids at 6500 miles and then the Prime at 4000 miles:).
    The wife wants to keep these for a VERY long time (she kept her 98 4runner for 18 years), so peace of mind if nothing else(y).
    Mendel Leisk and JC91006 like this.
  18. JC91006
    16,936
    8,647
    Nice to have money to burn. You'll probably buy the next self driving prius and the very long time theory will go out the door
  19. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    The CFO will step in;).
    The Prime is a great car and I’ve got a 150 mpg average going over 6300 miles:).
    Still on fill up #5(y).
  20. Mendel Leisk
    42,323
    Meh, $40 and an hour.
    Yes. My 2 cents: early fluid change is the best ploy. Then stretch it, say every 50K.
