Gen 2 Custom PID Traction Control
Discussion in 'Gen 2 Prius Technical Discussion' started by jrdamien, Aug 29, 2021.
  1. jrdamien
    jrdamien Junior Member
    57
    Minneapolis
    The PIDs for the Gen 3 have a traction control disable function. Is there a like PID for the Gen 2?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    I'm not sure if this what you're looking for, but, the DrPrius app has a function that will let you disable traction control for the duration of that key cycle on a Gen2.
    I'm a little confused because when someone mentions PID, I think of Parameter IDentification, or a single line item of data from an ecu. And I can't think of any value of seeing data indicating whether the traction control is disabled or not.
  3. jrdamien
    57
    Minneapolis
    Thanks. I hadn't even heard of that app. I will check it out!
