Gen 2 engine rebuild thread.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius92, Apr 25, 2023.
  1. Mendel Leisk
    42,355
    Reported. @Tideland Prius should be along shortly. :)
    (It's the button in lower/left corner of posts.)
  2. Tideland Prius
    16,681
    Title changed
  3. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    Preliminary cylinder head separation pics.
    The socket, which was over $60 with shipping from Snap On. Not only do they overcharge on tools, they overcharge on shipping. It was $22.95 UPS Ground 1 state away, when the actual cost was about $12.
    Valves.
    One of the cylinder bores. You can see the dark stains from blow by.
    Also keep in mind how gunked up everything is? I ran 4 tanks with fuel injector cleaner in it, Techron to be exact.
    SFO likes this.
  4. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    Subscribed! This will encourage me to tackle my engine!
    Any pitting in the cylinders? (I have a pitting in all of mine).
  5. Prius92
    595
    122
    Iowa
    No pitting as far as I can tell.
    Isaac Zachary likes this.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    nice to see all the cross hatch is still present. A couple minor vertical scratches? Are you planning to do a cleanup bore? I think they offer oversize pistons in half mm increments.
  7. Prius92
    595
    122
    Iowa
    From what I'm reading and I'll have to check, your not even suppose to hone the cylinders due to some kind of silicon coating on the bore. Machine shop said this kind of block can't be bored over because the connecting rods run at a slight angle and boring over will change that angle.
    Luckily I had a new one on the way, but I might of ruined the VVT solenoid, I put just the tip in my ultrasonic cleaner which turned it into an electromagnet, and the ohm reading isn't with spec.
    Here is the stuff I use to clean bolts and stuff, this will strip all grease right off.
    I might get new main and rod bearings, they aren't much aftermarket. Like $60.
    I've been smart and bagging/labeling the bolts.
    SFO likes this.
  8. Prius92
    595
    122
    Iowa
    Forgot to mention, the engine mostly sounds the SAME when you start it with the injectors and spark plugs disconnected.
    The hardest part about doing this rebuilding will be adjusting the lifters. There's not much room for play, and if one is out of adjustment, you have to order a different one, from 35, yes 35 different sizes through Toyota.
    The exhaust manifold bolts/nuts on both engines were in poor shape, luckily the intake manifold bolts/nuts are the same ones. Going to try and keep as many bolts as possible since they are nearly $2 EACH from Toyota.
  9. Prius92
    595
    122
    Iowa
    Also, why does Toyota sell the oil pump with the timing chain cover as one piece, when it looks like it can come apart?
  10. Prius92
    595
    122
    Iowa
    Donor engine right after removing the timing cover.
    The oil pump bolts seem sealed somehow. Used an impact and started striping the heads, so I stopped.
    After cleaning. The degreaser dulls aluminum a bit.
    Seal removed.
    Got the head off, the tops of the pistons seem to have less carbon than mine did. So hopefully the block has less wear.
  11. Prius92
    595
    122
    Iowa
    Can anyone find the part number for the clips that hold the crankshaft position sensor wiring to the timing cover?
  12. Prius92
    595
    122
    Iowa
  13. Mendel Leisk
    42,355
    Did you try parts.toyota? Good info source.
  14. Prius92
    595
    122
    Iowa
    No luck. Problem is Toyota groups things weird. Tried looking in engine, sensors, wiring, wiring harness, etc.
    I noticed a revision, the 06 intake has a blocked off vacuum port, the 08 doesn't. I'm not sure if the 04-05's had a vacuum system the later one's didn't need?
    This coolant pipe is a bit rusty, surely a new one can't be expensive, right? It's just a metal tube..
    $62?!? Nevermind...
    Also, here is the best diagram of the myriad of coolant hoses I've ever seen.
    SFO and Mendel Leisk like this.
  15. Prius92
    595
    122
    Iowa
    Some of the parts are insane.
    This input dampener? A new one is $636. Just...why?
  16. Prius92
    595
    122
    Iowa
    Monday both the donor engine bock and the block from my car are going to the shop to see which cylinder walls have more wear.
    Got the crankshaft main bearing caps, connecting rod bolts and main bearing cap bolts cleaned up.
    The donor engine has some rust on the walls, which I'm hoping can be fixed.
    SFO likes this.
  17. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    I hope you have marked which bearing cap goes where on what block (same for all the connecting rods).
    Usually, any machine work that's done on the engine block should have the main caps installed and torqued to specification.
  18. Prius92
    595
    122
    Iowa
    The main bearing caps are numbered 1-5 with a bulge on the cast pointing to the front of the engine. The connecting rod caps and rods themselves have a letter "U" stamped at different angles so matching them up is as simple as making the letter U legible.
    I also am going to have to order a new oil pan, because the stuff they use is extremely strong to seal it, and there was no flanges to slightly tap it off. It's called FPIG and it has 300 PSI of holding strength.
    I also can't find any real info online if they coated the cylinders on this engine or not. For some odd reason Toyota doesn't seem to list it. But you also can't easily get oversized pistons for it.
  19. ChapmanF
    19,037
    Whatever the New Car Features manual says about it is probably what you should go by. From what I remember (not in front of me at the moment), it says the piston skirts are coated with a resin, and that the cylinders are sleeved, and that the sleeves are thin, and not replaceable, and boring is not a thing.
  20. Prius92
    595
    122
    Iowa
    That sounds about right. Lined cylinders are a $$@#$@ nightmare because either they can't be honed AT ALL or you have to use some expensive diamond hone.
