WTB Gen 2 Engine.
Discussion in 'Private Sales' started by Isaac Zachary, Oct 7, 2023.
  1. Isaac Zachary
    Isaac Zachary Senior Member
    2,789
    1,508
    My 2006 Prius with 200k miles needs an engine.
    If you selling such an engine in or near South Western Colorado (all of Colorado, Eastern Utah, Northern New Mexico, etc.) I could come and pick it up to save on shipping.
    I do need an engine without frozen rings and cylinder galling. I'm not too particular about mileage, but mainly as long as I can scope the cylinders to check for damage before purchase is what I'm asking.
  2. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    Have you checked the local salvage yards? I got mine a few years back for $175 they don't go for much because they rarely blow up.
    Isaac Zachary likes this.
  3. Isaac Zachary
    2,789
    1,508
    Thanks! I'll check. There are a couple salvage yards that are only 2 hours from here. One does deal mainly with Toyota and other Japanese imports.
    Prius Rising likes this.
  4. wrench
    wrench Member
    157
    55
    Sunnyvale, CA
    If you decide you are willing to buy a rebuilt engine, I can give a two thumbs up for Hybrid Pit in Southern California. I have had good luck with them. Setup your own shipping though. I found what they offered to be on the high side.
  5. wrench
    wrench Member
    157
    55
    Sunnyvale, CA
  6. wrench
    wrench Member
    157
    55
    Sunnyvale, CA
  7. wrench
    wrench Member
    157
    55
    Sunnyvale, CA
  8. wrench
    wrench Member
    157
    55
    Sunnyvale, CA
  9. Isaac Zachary
    2,789
    1,508
    Thank you, but if these engines were rebuildable, I'd rebuild it myself.
    Hybrid Pit claims they bore and hone the cyinders. However, as far as I understand, you can't/shouldn't bore and hone Prius engines. Maybe if they resleeved them, but I doubt they do.
  10. wrench
    wrench Member
    157
    55
    Sunnyvale, CA
    I thought about doing that, but I've not done one before. Plus, I needed the car up and running again, so I just got one of their rebuilds. So far, it has worked flawlessly. We've probably got 10K on it now (just a guess... my daughter has the car in another city, so I don't check it that often). The car was in great condition otherwise, so I wanted something that give her reliable transportation.
    Anyhow, please post pics of your rebuild, although the engines are pretty much stock on a lot of the smaller Toyota vehicles.
  11. Isaac Zachary
    2,789
    1,508
    Well, like I said before I don't consider these engines rebuildable. Toyota does not recommend rebuilding. It would need to be resleeved, and that's not recommended. Hybrid Pit doesn't even mention resleeving, which makes me even more nervous.
    I'm either getting a used engine or a new engine. I do not want a rebuilt engine.
  12. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    Call the salvage yards even if you have to drive several hours to get it the cost savings will be more than worth it. I bet ebay has them with shipping but you will pay a lot more. (y)
  13. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
