Gen 2 headlights
Discussion in 'Gen 2 Prius Technical Discussion' started by ruidboi, Sep 5, 2018.
  1. ruidboi
    ruidboi Junior Member
    45
    Nassau, New Providence
    What’s causing my gen 2 Prius right headlight not to turn on sometimes? I’ll have to turn off and and on a few times for it to turn back on. I changed the bulb it worked perfect for a few months then does the same thing again. I even used expensive Phillips bulb.
    iPad ?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The failure mode of HID headlights is that they work when cold but not when hot. Often this makes them blink, but it also means they work on a cold start but not once you get running. Sounds like you need another bulb.
    High-intensity discharge lamp - Wikipedia
  3. ruidboi
    45
    Makes sense it always works on cold start. The odd thing is I had the car for 5+Years and the left headlight hasn’t gone bad yet. It’s only the right one that’s gone bad 3 times. I thought there was something I can do to prevent it from failing prematurely again. I’m sure a new headlight would fix it for a while.
    iPad ?
  4. JC91006
    16,936
    8,646
    Try buying bulbs at home depot, genuine stuff
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  6. MichaelKnight
    MichaelKnight Junior Member
    39
    22
    Westcoast
    Swap the driverside to the passenger. And passenger to driverside.
    Test (few days) and verify if the issue follows the bulb or stay with the original headlight.
    Pause from buying any other hid bulbs till you try the above method.
    hope this helps
    Shaunius likes this.
