For Sale Gen 2 HV battery built with Gen 4 modules
Discussion in 'Private Sales' started by TMR-JWAP, Jan 17, 2018.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    No problem. Let's pencil it in for early July. We can work out the details as we get closer.
    Raytheeagle likes this.
  2. tnt01prius
    tnt01prius Member
    105
    Surprise, AZ
    TMR-JWAP,
    I'm going to repack my gen 2 with gen 4 mods tomorrow. From what I can tell, it looks like I might be able to swap the entire pack of mods stripped down with end caps still attached. There are a few differences to work around, so even if it could be done, I guess it wouldn't be worth it?? Is there a market for a good second hand gen 4 hybrid battery case I won't be using? All like new from 2017 Prius, 13,000 miles.
  3. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    The issues you'll need to work around are:
    1. the side clamps on the gen 2 are smooth on top except for the bolt bosses. The gen 3 (and gen 4 iirc) have extra tabs on top for cables. I've used gen 3 clamps in my gen 2 builds because they have better reinforcement, but I machine off the extra tabs so the black plastic trim piece fits correctly.
    2. the gen 2 clamping bar set has a small metal tab at the non-ecu end for mounting a temperature sensor. No big deal, since it's your battery, you can zip tie it if desired.
    Personally, I would put the new modules into the old clamp set. Just make sure you note the orientation of the + and - and make sure the gen 4s are installed exactly like the original gen 2 modules. It's very easy as they interlock together.
    No significant market for gen 4 cases, that I know of.
    SFO likes this.
  4. Prodigyplace
    12,711
    11,848
    Central Virginia
    Be sure the Gen 4 battery is NiMH. Most US models use LI-Ion.
  5. tnt01prius
    tnt01prius Member
    105
    Surprise, AZ
    okay that's scary - I just rebuilt my hybrid battery, but I'm too frustrated to figure out how to post a pic and not lose everything I typed twice. Anyway thanks to all here for sharing your experiences. My results of going from a 14 y/o hybrid battery to 2017 mods is looking real good. Up and running and the first trip of 29 miles is showing about 10 more mpg in mixed normal driving I'm blessed and very grateful.
  6. Prodigyplace
    12,711
    11,848
    Central Virginia
    According to Toyota they used a higher grade of Nickel in the Gen 4 cells too.
    Perhaps longer lasting?
  7. Toddwilks
    Toddwilks Active Member
    555
    177
    Whitehouse Station, NJ
    If you start another one I’d be really interested. I’m in central jersey but my parents are in Taylor’s SC.
    iPhone ?
  8. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    This looks like a heck of a lot of time and work. Don't know how there's any money in doing it for $1600. But it certainly is admirable. Alternatively, you Gen 2 and later owners can get those new stock round modules to rebuild your batteries. Same price. Equally good deal, I think.
  9. Prodigyplace
    12,711
    11,848
    Central Virginia
    Only if you are referring to @2k1Toaster kit of new cells. There is another vendor (CEBA?) using the same mounting with inferior cells. The link for the good ones is in my signature.
    Brian in Tucson likes this.
  10. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    That's the one I was thinking of. My brain seems to be a bit porous these days.
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Would that be dimes? <rimshot>
    :p
    jerrymildred and Prodigyplace like this.
  12. Prodigyplace
    12,711
    11,848
    Central Virginia
    The press release did not say so I did not press the matter. ;)
  13. fotomoto
    5,639
    3,815
    So. Texas
    Maybe it's a new current-cy?
    Oh, that was really bad. I'll stop now..... :censored:
  14. goitalone
    goitalone Member
    190
    16
    Port St. John, Florida
    Anymore like this for sale?
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Like what? 2k1Toaster's kit or a gen 2 battery with gen 4 cells?
    If the former, check with @2k1Toaster.
    If the latter, Todd at Home - Tampa Hybrids Inc. probably can fix you up. I don't think he'll ship, but it's a nice drive from your area.
