For Sale Gen 2 HV battery for Jacksonville, FL area.
Discussion in 'Private Sales' started by TMR-JWAP, Jan 27, 2019.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    I'm going to be in the Jacksonville area from January 28th through February 8th, give or take a day if needed. I'll be working some potentially long hours helping to bring one of our new sister facilities on-line.
    As a side hobby, I build Gen 2 HV batteries using modules from late model low mile wrecks. I've built and installed batteries for several fellow forum members. I'll be taking an HV battery with me on the trip, just in case a forum member in the area is interested. This battery was built using modules from a low mileage 2016 Prius. It has NEW busbars/sensor harness, etc and was installed in my car for 2 weeks for testing. I removed it last week and re-installed my normal Gen 2 daily driver battery. This battery is available for $1250 installed (+ your old battery).
    Three year guarantee on the battery. I have full confidence this battery will be good for much longer than that. Because my schedule is a bit up in the air right now, I'll need a bit of flexibility. I could probably do this anywhere within a 3 hour radius of Jacksonville, unless I manage to get a full day off, which could extend that out a bit more if needed.
    I have techstream so we can do a full health check of any Toyo vehicle. I also have new Toyota inverter cooling pumps available if desired. I install new inverter cooling pumps for $150, which is about $400 less than a dealer.
    Just respond to this post or use 'start a conversation' to get in touch.
    chelvis, SFO and Raytheeagle like this.
