Gen 2 key fob malfunction?
Discussion in 'Gen 2 Prius Technical Discussion' started by donzoh1, Jan 14, 2023.
  1. donzoh1
    donzoh1 Active Member
    450
    153
    Lenexa, KS
    My 2008 has needed a couple of jump starts recently. Also, now the car is stuck in neutral, not starting, and won't release the key fob. Lights work but fob stuck and no start. To make things worse, the car is in Waterville, Maine which is 1500 miles from me. Any ideas?
    Update: The key fob came out and I've been informed that the lights don't work. Other information is correct. I'm going to have my daughter check the battery at this point.
    #1 donzoh1, Jan 14, 2023
    52,747
    it does sound like the battery. how old is it?
  3. donzoh1
    450
    153
    Lenexa, KS
    Battery is fairly new...maybe 5 mos? AutoZone or something like that AGM for around 240 bucks. It's in Maine so I know that's cold up there. Also, do not know what the guarantee on it was. Apparently, dash lights did come up while it was being jumped or attempted to be jumped. No other signs of life tho.
  4. donzoh1
    450
    153
    Lenexa, KS
    I'm leaning toward the idea that the battery is low but I'll have her get the battery tested. There was a recent similar failure but a jump start was successful in that case. Here, the jump start had no effect.
  5. bisco
    52,747
    auto zone does free load tests, maybe other parts stores.
    another possibility is someone cross connected the jumper cables, possibly blowing a fuse or worse
    donzoh1 likes this.
  6. donzoh1
    450
    153
    Lenexa, KS
    I will start with battery testing. Assuming the battery is good (it's only about 6 months old but still could be defective) do you have an opinion as to what parts would be most likely damaged by improper jump starting? If I repair this, I might take a bunch of parts with me just to be sure I have what I need because of how far the car is from home. I would get these parts mostly from part out cars or the junkyard and then sell the parts not needed later.
  7. bisco
    52,747
    the inverter can fry, but most often it's just a fuse. you should be able to locate the fuse by searching google and adding priuschat
  8. bisco
    52,747
  9. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    It is likely not just a fuse. There are three or more that should turn up in your search of PriusChat forums. Don't forget to check the 5 A fuse on the positive terminal battery block itself.
  10. donzoh1
    450
    153
    Lenexa, KS
    Thanks. I've heard the 08 and 09 inverters are better than the earlier gen 2 but do not know whether that means they're better protected against frying.
  11. bisco
    52,747
    idk that either
