Gen 2 knock sensor location
Discussion in 'Gen 2 Prius Technical Discussion' started by Wecandothat4u, Oct 21, 2023.
  1. Wecandothat4u
    Wecandothat4u Junior Member
    57
    Cambridge, MN
    Where is it?
  2. PriusCamper
    PriusCamper Senior Member
    13,329
    5,393
    Pacific Northwest, USA
    I just googled it and it looks like it's on the front facing side of the engine block in most all Toyotas... So I suspect this photo I found is likely accurate despite being a Gen3 engine and not a gen2.
    Wecandothat4u likes this.
  3. Wecandothat4u
    57
    Cambridge, MN
    I Googled it as well but like you, only found Gen3 and didn't even look at it. Figured someone here would know for sure.
    Thanks. I'll look there.
    PriusCamper likes this.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,010
    NJ-USA
    Well, I've never had to take a Gen2 apart but the service manual had this to show.
    That's as "sure" as I can get. (The torque specification is important for this sensor)
    PriusCamper and Wecandothat4u like this.
  5. Wecandothat4u
    57
    Cambridge, MN
    Looks good. Thanks.
  6. Wecandothat4u
    57
    Cambridge, MN
    Thanks to both of you for the help.
    #4 Wecandothat4u, Oct 22, 2023
