Gen 2 LED Headlights?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Animaza, Jul 31, 2021.
  1. Animaza
    Animaza Junior Member
    Nevada
    Are there any Gen 2 LED Headlights on the market? Like not the bulb, but the whole housing be led with like daytime running lights and all?
  2. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Assuming you need a new housing for some reason and not just do a build swap? Or are hell bent on drl? Maybe with a two step using this and then swap halogen for one of many of the choices for LED bulb also on Amazon.
  3. Animaza
    Nevada
    I already have LED bulbs for the headlights in my HID housing. Was a simple swap and drop. But I was wondering if there is any full LED Housings being made. For example search "mustang led lights". Companies make tons for those cars but i've yet to find any made for gen 2 prius.
  4. Another
    1,819
    520
    Naples, Florida
    Oh. I’m curious which LED bulbs do you have for the HID? Was it a simple conversion or do you have to change the other components? Are they on Amazon?
  5. Animaza
    Nevada
    Sorry for the late reply. Yes I got them on amazon. Here they are:"
    "Was plug and play for me. Only works with HID headlights not halogen.
  6. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    Are you sure? They look like drop-in halogen replacements to me.
    The ad says in one place, "High Brightness - AUXITO H4/9003 LED headlight uses customized ZES chips, 12000LM, 52W per set, 200% brighter than halogen headlights."
    And then further down it says, "
    Easy to Install
    AUXITO H4 LED bulbs are fully all in one designed, do not have external driver and connector, directly plugged in just like halogen bulbs. Non-polarity socket, plug and play.
    Make sure the two sides of the LED chips face 3 and 9 o'clock direction after installed."
    Both these reference halogen, not HID.
  7. Another
    1,819
    520
    Naples, Florida
    Anyone had any experience with these HID to ALLA LED modules?
  8. outtabounds
    outtabounds Junior Member
    52
    Metairie, LA
    I cant stand the HIDs. I want the same, an affordable led assembly plug and play to hid connectors.
  9. outtabounds
    52
    Metairie, LA
    Not for $90. Need to find a $20-$30 option.
  10. dolj
    dolj Senior Member
    8,640
    4,391
    I doubt you'd find anything decent for $90, so good luck with your quest.
    I think too many Americans trade quality for price and think they scored a bargain.
  11. outtabounds
    52
    Metairie, LA
    I ordered a set for $30. I agree but if there all from China and made in the same factory it doesn't make a difference IMO. Like ordering JDM parts online that arrived marked made in china. Just my opinion. I also ordered aftermarket smoked headlight assemblies without the amber side markers. My understanding is its just 12v two wires and bypassing the ballast to convert them to LEDs. The HIDs are so bad and pricey. I can barely tell the lights are on. I wish my car had the halogens. That is after replacing both ballast to get them work in the first place.
  12. outtabounds
    52
    Metairie, LA
    I finally got LEDS that work. Not an ad not sponsored. These just worked for me so sharing. They were $55 but I'm so happy to have the HID and Ballast gone. I wired them directly 12v inside of the assembly to the two wires that goes through the dustcap. I removed the ballast completely and took it apart and reinstalled only the black top part of the metal cover and the seal so the assembly is sealed. They have been working great and high beams work fine. The high beams are a cap so you don't need to mess with that. The videos I watched were way over complicated and running the ballast through an assembly is a nightmare. This was the easiest way I got them to work with only cutting one pair of wires inside the assembly and not cutting into the cars OE harness.
    Amazon
    D2H LED Bulbs No Ballast Required D2S D2R D1S D4S D3S D4R D8S D2C D1R D1C D3C D3R 110W 30000Lm Super Bright 12V 6500K Cool White Fog Lamp 2pcs
