Gen 2: List of recommended related parts to replace when (using OEM) replacing HV battery
Discussion in 'Gen 2 Prius Main Forum' started by Priusjames, Aug 22, 2021.
  1. Priusjames
    Priusjames Member
    91
    68
    Irvine, CA
    I’m going to do the OEM hybrid/traction battery rebuild. I looked, but didn’t see any posts cleanly listing the parts related to replacing/rebuilding the battery w OEM battery.
    Q: What parts did you see as you went along that you wished you had ordered before you were in the middle of the job?
    I know there’s stuff that needs to be moved from the old battery to the new and a core returned, but not what stuff that is/isn’t.
    I’ll go to YouTube and start watching videos, of course, but know this community will have some smart insights. TIA!​
    52,447
  3. Priusjames
    Priusjames Member
    91
    68
    Irvine, CA
    That's the thread I was looking for! It's not really chock full of the information I hoped for, but has some tidbits for sure.
    I'm kind of surprised I can't find videos here or on youtube other than "unbolt the old one and put in a remanufactured entire unit from somebody else," also addressed in the thread.
    Thanks
    -J
    #3 Priusjames, Aug 22, 2021
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    If you're doing the OEM battery replacement, one of your concerns will be the battery ecu. Your new OEM battery will have a new "wire frame #2", but frequently the ecu has significant corrosion on the socket pins where the WF#2 is inserted.
    Also give the cooling fan a good cleaning while you're in there.
    You'll also see a set of wires near the cooling fan bracket with a plug and socket. That plug and socket often develops corrosion on two of the pins and is typically very obvious. Now would be a good time to just cut the wires on each side of the plugs and splice them together. I've done it on all my Gen 2s and many customers.
    Priusjames likes this.
  5. Priusjames
    Priusjames Member
    91
    68
    Irvine, CA
    Perfectly the kind of hints that help, thanks! I've done the fan cleaning before but didn't know about the other hints,
    I guess I'm the next person telling myself I'll make a video of the process when I do it now, heh. I'll make sure to cover any hints/tips I get in this thread when I do it in my mind. Thanks again.
    SFO and bisco like this.
  6. PriusZombie
    PriusZombie New Member
    Orange County, California
    I am getting a new battery!
  7. rogerthat
    rogerthat Active Member
    410
    126
    Georgia
    Can someone confirm that new oem batteries come without the two rubber vent tubes?
  8. dolj
    dolj Senior Member
    8,589
    4,361
    Wellington, New Zealand
    Yes confirmed, they do not come with new vent tubes. You reuse the old ones.
    If they are smelly, you can fashion replacements from some silicon tubing. I think some people might even leave them off entirely if they were smelly, gooey or otherwise objectionable.
  9. rogerthat
    410
    126
    Georgia
    Thanks. I notice you are in New Zealand... assuming this will be the case in the US too. I'm very familiar with the smelly vent tubing issue - I replaced mine with silicone tubing shortly after I bought my car.
    dolj likes this.
  10. dolj
    dolj Senior Member
    8,589
    4,361
    As far as I am aware the back end is identical.
    Nice.
